990 SD sprocket change threadlock?
Postby RichUK » Tue Sep 05, 2017 3:31 pm
I'm reading through the workshop manual and it's confused me..
It states in Section 10 page13
Replacing the chain, pinion and rear sprocket
– Unscrew the engine sprocket cover 1, bend up the lock washer 2 and loosen the engine sprocket nut 3.
– Open the chain with a cutting/riveting tool (see page 10-14) and remove the chain.
– Remove the engine sprocket with the lock washer (+ Loctite 243!).
– Slip on a new pinion with a lock washer and screw on the nut.
So does that mean that the sprocket nut has Loctite 243 on it?
Further down that page it states
Tighten the engine sprocket nut to 100 Nm, bend up the lock washer.
– Screw on the engine sprocket cover.
– Adjust the chain tension (see Owner's Manual).
So no mention of applying (or reapplying) Loctite 243?
Re: 990 SD sprocket change threadlock?
Postby No. 47 » Tue Sep 05, 2017 3:38 pm
Parts fiche doesn't refer to 243 as it does for bolts, etc elsewhere.
Postby DribbleDuke » Tue Sep 05, 2017 5:05 pm
RichUK wrote:I'm reading through the workshop manual and it's confused me..
I think the Loctite is for rear sprocket bolts
Postby RichUK » Tue Sep 05, 2017 5:10 pm
No. 47 wrote:Parts fiche doesn't refer to 243 as it does for bolts, etc elsewhere.
yeh, I just thought it strange it mentions it wrt to removing the front sprocket nut.
So probably just an error in the manual I guess... :roll:
