Motorex Boxer Oil?
Motorex Boxer Oil?
Postby Sarasota_Steve » Tue May 08, 2018 8:35 pm
Re: Motorex Boxer Oil?
Postby Aphex » Tue May 08, 2018 8:45 pm
I dont think it has anything to do with the fact its for boxers but maybe because its a thicker oil? My Motorex rep recommended me 10w|50 for so cal and this is 15W|50.
I'm not an oil expert at all though, so who knows.
Postby RichUK » Wed May 09, 2018 8:31 am
The 15W just means it will be thicker when cold, which is when you don't want it to be thicker, although it may help with cold engine rattles.
It might also help to close up ring gaps when cold and reduce oil burning then.
Closing the gap between the cold and hot viscosity numbers is a good thing because it should mean less VI modifiers have been used, so the oil may stay in grade for longer.
There will however be less flow when cold, and/or it will bypass the filter for longer, both of which are bad things.
Postby RichUK » Wed May 23, 2018 11:01 am
Just doing a little oil shopping and that boxer stuff is priced well compared to others in the range.
Motorex Boxer 4T 15w50 1 Litre - £10.99
Motorex ATV Quad Racing 4T 10w50 1 Litre - £12.99
Motorex Top Speed Syn 4T 15w50 1 Litre - £14.99
Motorex Cross Power Syn 4T 10w50 1 Litre - £17.99
Motorex Power Synt 4T Racing Oil 10w50 1 Litre - £17.99
Motorex Racing Pro 4T 15w50 1 Litre - £22.99
I'm probably gonna stick with Silkolene Pro 4 though.
scamb66
Postby scamb66 » Tue May 29, 2018 2:57 am
RichUK wrote:The 15W just means it will be thicker when cold, which is when you don't want it to be thicker, although it may help with cold engine rattles.
Living in Florida though it is considerably warmer and probably not so much of an issue. In older vehicle here in Oz I always run 20w-50 as anything finer usually increases consumption.
Would I run it in the SD? Probabaly after 50k miles.
