990 duke battle belly pan
Advertise here for any items you want to buy....bikes, parts, etc.
Be sure to include your location, size (if applicable) and any other relevant info.
dipper
Postby dipper » Fri Aug 18, 2017 7:31 pm
As title. Belly pan from the SD battle series required
Re: 990 duke battle belly pan
Postby bic_bicknell » Sat Aug 19, 2017 7:35 am
You used to be able to get them from Skidmarx. I had them make me a carbon fibre one from the same mould. Cost an arm and a leg though! Actually I just looked at their site and the bellypan isn't the one I got. Maybe they've changed it or maybe I got mine from elsewhere.
https://www.skidmarx.co.uk/ktm/990-supe ... y-pan.html
I think maybe mine is one of these...
http://www.replicastuk.com/prod5.asp?ID ... od_id=8388
Bellypan thread on Supeduke.net here...
viewtopic.php?t=10641
dipper
Postby dipper » Sat Aug 19, 2017 7:55 am
Think I prefer the replicast one. How does yours cope with the heat? Did it need heat proofing?
Postby bic_bicknell » Sat Aug 19, 2017 9:39 am
When I originally fitted it I put a layer of self adhesive heat foil on the inside of the carbon where it came close to the front header. But over the years it's come away and now there's nothing and there's no adverse effect from the heat. But that's carbon and not GRP so can't really comment on that. What is a pain is that the horn doesn't really fit inside the bellypan and even though I'm always fiddling with the bracket and bending it this way and that so often the horn does not work by the time all the bolts are done up because the edge of it hits the pan and stops it beeping. Not really bothered because the horn is so shit anyway. :wink:
dipper
Postby dipper » Sat Aug 19, 2017 10:29 am
Thanks bic. I've got a slightly worse for wear grp one here fitted to an early SD. There's definite signs of bubbling due to heat. Also, just had a quick look and the horn has been rotated 90deg and works fine. Will take the belly pan off later to check if he's just bent the bracket or made up a new one
Have to say, I'm tempted with the carbon one as I guess it's a good bit lighter although I'd probably end up painting it Black!
shadowman
Postby shadowman » Sat Aug 19, 2017 3:09 pm
This is my old bike withe the belly pan I fitted which I think has the best lines on a 990
http://s760.photobucket.com/user/Barkin ... a.jpg.html
Only trouble is I cant remember the make. I got it direct fromthe UK manufacturers who were sekking on eBay if thats any help.
Recovering superbike addict
dipper
Postby dipper » Sat Aug 19, 2017 4:02 pm
if it was one piece it would be fine but i'm not keen on the 2 part look.
Postby bic_bicknell » Sat Aug 19, 2017 6:33 pm
One other thing. If you get a proper race belly pan like I did it has to be oil tight. Which means that it also fills up with water and rain when it's wet. I got fed up with always having about three inches of water in the bottom of the pan so I drilled a 10mm hole and fitted a rubber plug so now all I need to do is remove the plug and it self drains.
Postby No. 47 » Sat Aug 19, 2017 11:41 pm
Correctly fitted, Replicast fibreglass pan will last 30-40k miles - have had three so far and about to order fourth.
WhiteSoul
Postby WhiteSoul » Fri Oct 20, 2017 2:43 pm
@No47, where do you order it from ?
I al looking for one, plus a front mask, do you know where I could find them ?
Thanks !
Postby No. 47 » Fri Oct 20, 2017 3:28 pm
As above......................http://www.replicastuk.com/prod5.asp?ID ... rod_anchor
Call, rather than email, them - any problem re shipping abroad, happy to help.
Postby No. 47 » Fri Oct 20, 2017 3:31 pm
PS - order two fixing brackets if you do not want to lose/modify side stand mounting.
WhiteSoul
Postby WhiteSoul » Fri Oct 20, 2017 4:15 pm
Thank you.
As the link was not coming from you I figured you might have another "contact".
The side stand is a pain in the a***, scratching the ground before everything else on track... I will take it out.
Return to Wanted
