LSL Drag Bars.
Advertise here for any items you want to buy....bikes, parts, etc.
Be sure to include your location, size (if applicable) and any other relevant info.
LSL Drag Bars.
Postby Aphex » Fri Sep 29, 2017 10:13 pm
Cannot find these anywhere in the US for less than $130.
Re: LSL Drag Bars.
Postby No. 47 » Sat Sep 30, 2017 3:50 am
Just fitted Rizoma drag bars to mine - £85 in UK and circa $82 in US.
speedfiend41
Re: LSL Drag Bars.
Postby speedfiend41 » Sat Sep 30, 2017 4:25 am
Aphex wrote:Cannot find these anywhere in the US for less than $130.
Yep. Not cheap but worth it! Best mod if you want more weight over the front without going all the way to clip ons.
Re: LSL Drag Bars.
Postby Aphex » Sat Sep 30, 2017 11:20 pm
No. 47 wrote:Just fitted Rizoma drag bars to mine - £85 in UK and circa $82 in US.
I think I'll go with the Rizoma bars. I never thought Rizoma would be a cheaper alternative to anything else, could I get a pic of your bars? Did you have to trim them?
Re: LSL Drag Bars.
Postby No. 47 » Sun Oct 01, 2017 11:33 am
No trim, longer head stock stop bolts required.
PBRnr
Re: LSL Drag Bars.
Postby PBRnr » Mon Oct 02, 2017 6:35 am
PM sent
Re: LSL Drag Bars.
Postby Aphex » Mon Oct 23, 2017 12:28 am
Anyone have a pic of how they routed their throttle cables?
I tried a couple different ways and it seems to still cause it to surge.
I probably have to adjust the throttle slack via the tube. :oops:
Spike_africa
Re: LSL Drag Bars.
Postby Spike_africa » Thu Oct 26, 2017 12:49 pm
Correct me if I'm wrong these are factory fat bars on these standard right? Not the normal 7/8" clamp in the middle. So like a Renthal fat bar or LSL or Protapper fat bar will bolt right on.
2007 SD 990
2009 Triumph Street Triple
Re: LSL Drag Bars.
Postby Aphex » Thu Oct 26, 2017 2:42 pm
Spike_africa wrote:Correct me if I'm wrong these are factory fat bars on these standard right? Not the normal 7/8" clamp in the middle. So like a Renthal fat bar or LSL or Protapper fat bar will bolt right on.
Correct.
The LSL Drag bar's I'm using are the "Drag bar fat bar" version. The diameter in the clamp area is 1 1/8" (28.6mm); OD at the grips is 7/8" (22.15mm); ID is 14mm.
Return to Wanted
