Handle Bars and Bends
DRW
Postby DRW » Sat Dec 12, 2009 7:11 pm
Other than the OEM bars, has anyone played with different bends and or brands? Just wondering..
2008 KTM Super Duke 990
2006 KTM 450EXC
2006 TRIUMPH SPEED TRIPLE 1050
Postby bic_bicknell » Wed Dec 16, 2009 7:16 am
This is my mission at the moment, I want to find flatter, tapered bars that put more weight over the front end. I'll post anything I find.
DRW
Postby DRW » Wed Dec 16, 2009 11:23 pm
That makes sense, i am a dirt rider and feel bar bends and position in key to handling. Just wondered if anyone has played with different bends, widths, and brands.
2006 KTM 450EXC
chris2
Postby chris2 » Thu Dec 17, 2009 4:05 am
Postby bic_bicknell » Thu Dec 17, 2009 7:08 am
Chris, do you know the Renthal part number for those bars? Also it's hard to see from the pic, is the rise less than standard? I guess you could cut the width down a bit if you wanted.
DRW
Postby DRW » Thu Dec 17, 2009 9:08 pm
Those look like the factory Renthals from KTM accessory book. Very nice bars and i believe they are Renthal KTM bend.
2006 KTM 450EXC
chris2
Postby chris2 » Fri Dec 18, 2009 5:33 pm
bic_bicknell wrote:Chris, do you know the Renthal part number for those bars? Also it's hard to see from the pic, is the rise less than standard? I guess you could cut the width down a bit if you wanted.
Rise is close to the same as the KTM factory bars. I got it from KTM Twins a while ago: http://www.ktmtwins.com/990superduke/r609-01-blk.html
roamer
Postby roamer » Mon Dec 21, 2009 3:17 pm
I just added the KTM bar risers.
I wanted to get a little tighter steering, for parking lot maneuvering.
The new, longer bolts are about 5 threads too long.
If you turn in the steering stop bolts, the new, longer bolts will contact the frame, preventing any gain. Trim the bolts to length before tightening it all up.
Jaxian
Different obstruction for me with stock bars.
Postby Jaxian » Tue Dec 22, 2009 8:41 pm
I also just added the KTM bar risers and the bolts do stick out the bottom about 5mm. I never noticed to be honest because, at least on my bike, the fork tubes hit the radiator cover shrouds before those bolt ends hit. I set mine up with a 1mm gap between the fork tube and the black plastic shroud things/radiators and then set the stops accordingly. I can go take pictures if anyone wants to see them at full lock.
Amusingly the only annoying thing about the risers is the fact that when you go to lock the steering head by taking the key out you always have to turn it back a few inches from full lock before the pin will set. Small price to pay though. I still have the stock bars and this is on an '08.
Freestyler
Postby Freestyler » Tue Dec 22, 2009 10:07 pm
bic_bicknell wrote:This is my mission at the moment, I want to find flatter, tapered bars that put more weight over the front end. I'll post anything I find.
Call KTM center hemel they have just fited a set of Renthul black bars to a An ,R, for a custermar . they mite be just what you are looking for , and they got two sets in so they are on the Rack £61, I think .
onley Ded fish go with the fow.
I Hate to advocate Drugs Alkcahol Violence or ,Insaneity, To eney one but they'ev allways warked for me .
Hunter S Thomson ,RIP.
paddle faster
I hear Banjos
Postby bic_bicknell » Mon Jan 04, 2010 8:52 pm
I went to Hemel at the weekend and had a look at the SDR with those bars. They are so nearly what I want, they are lower and definitely pull back less than standard but they are quite a bit wider and the bar shape means that I don't think that you can cut off the ends and push in the controls because the switch gear cannot move in.
I really don't want wider bars - mainly 'cos of commuting through London, even standard bars are at the limit for me there otherwise filtering through traffic would be too stop/start! But thanks for the tip, I will keep on looking. Hemel says that Renthal will probably do something exactly like I want.
BASH69
Race ace
Postby BASH69 » Wed Jan 06, 2010 8:33 pm
Try and get your hands on some Ducati Streetfighter bars! :wink:
The official owner of the big pink SDP (thats STUPID DUKE Poofs edition to you).
BASH69
Race ace
Postby BASH69 » Wed Jan 06, 2010 9:15 pm
smoky
Postby smoky » Thu Jan 07, 2010 3:57 pm
check out these spiegler pages, this should give you an idea what's out there and what choices you have for raise and pull-back...
http://www.spieglerusa.com/cfm/handlebars.cfm
http://www.spieglerusa.com/cfm/fathandlebars.cfm
"Idiot-proofing everything creates a world full of idiots!"
Resmas
Postby Resmas » Tue Jan 12, 2010 8:25 am
Does anybody know thw dimensions of the OEM stock bars?
The Rizoma ones state that they Will fit with the Rizoma 29mm handlebar clamps. Does that mean tou have to get the clamps too?
rgds
Luis
SD rules...
Freestyler
Postby Freestyler » Tue Jan 12, 2010 11:43 am
bic_bicknell wrote:I went to Hemel at the weekend and had a look at the SDR with those bars. They are so nearly what I want, they are lower and definitely pull back less than standard but they are quite a bit wider and the bar shape means that I don't think that you can cut off the ends and push in the controls because the switch gear cannot move in.
I have got a set of Duke three bars here iff you whont to offer them up on your bike you wood be welcome to try them iff you like , iff you finde your self out for a ride up near stevernige , Iam only just off Junk'8, of the A'1M north bownd . theys bars are defanetley straghter and just a tad whyder than the standed ones .
paddle faster
I hear Banjos
Postby ktmguy » Wed Jan 13, 2010 9:13 am
I have a set of Fly Aero tapered bars arriving tomorrow. Never heard of them before but they looked good and solid, and...are cheap so if they don't work no big deal.
The original bars give my bad wrist a hard time so I want to find something that fits me, they are also a bit lower.
I'll keep your posted....
Resmas
Postby Resmas » Sat Jan 16, 2010 8:20 pm
Hi Bic, found anything u where looking for? I want to change the bar too but don´t want any wider bar, just different colour (black) and improved riding maybe.
The Rizoma Fat Bar looks good but imply a change in the handlebar clamps/risers, i.e., +83£ for the 29mm bar. The question is, they are risers, do they rise in comparison with the original clamps? If so then the riding position will be greatly affected, a more straight position which i believe is precisely the opposite idea. Correct me pls if i´m wrong. Is the 29mm referring to diameter of the bar or to height of the clamps?
rgds
luis
SD rules...
Postby Lowrance » Sun Jan 17, 2010 12:55 am
29mm is the diameter of the bar where it contacts the bar mounts. You will not need the Rizoma bar clamps, the stock ones will work fine.
John
Postby bic_bicknell » Sun Jan 17, 2010 8:42 am
I've been delaying my decision while I look further. It's not an urgent need. I like the Rizoma ones but then I found this thread from ages ago and have been trying to track down whether they are still available.
http://www.superduke.net/forum/viewtopi ... light=horn
Links don't work anymore but the manufacturers are still there - all in French and no reference to bike handlebars. I've got a French friend checking for me.
I'm like you Resmas, just want bars that are a bit lower and maybe further forward. Definitely not higher and definitely not wider.
BASH69
Race ace
Postby BASH69 » Fri Jan 22, 2010 7:58 pm
Seems Strawber only make parts for pedal bikes nowadays! -
http://www.strawber.com/strawber-ENG/home_TECH.html
Stew :?
Postby bic_bicknell » Fri Jan 22, 2010 8:43 pm
That's as far as I got too!
Can't find a trace of them anywhere. Shame really - they were interesting.
BASH69
Race ace
Postby BASH69 » Sat Jan 23, 2010 9:14 am
Il bet they had a few failures and realised things cud get real expensive (legally) real quick!!!
Coerce make the perfect bars for my needs but unfortunaly they only make em in 7/8 size, shame as they only cost £50 inc shipping to UK -
http://www.pacmax.com/coerce%20hpbar.html
Check thier comp low bars!! :cry: :cry: :cry:
Freestyler
Postby Freestyler » Sat Jan 23, 2010 1:51 pm
Eney one thort abowt fitting a set of aprilia Tuono bars on there sd ,or is it just me ! .
paddle faster
I hear Banjos
kuerbis
Postby kuerbis » Sat Jan 23, 2010 3:45 pm
Freestyler wrote:Eney one thort abowt fitting a set of aprilia Tuono bars on there sd ,or is it just me ! .
These look sweet! Now if I could just find out if there is enough room for the controls/switch gear. Anyone have a Rizoma dealer close by? I think I'm going to take a measure to the Aprilia Dealer and measure the stock bars. If I find any thing that looks close to fitting the SD I will report back.
Kuerbis
