.HEX Maps for TuneECU and Custom PCIII Maps Downloads
Postby Colonel_Klinck » Tue Nov 30, 2010 8:13 am
All links now updated and working again. Finally got it done. :D
Guys I have finally got my lazy arse into gear and uploaded all the TuneECU maps to DropBox. They should all be working correctly but please check file name of map against what you wanted before installing with TuneECU. Remember I do like a joint or 3 and although I wasn't high when I uploaded these maps I can't be held responsible if I have fooked up and uploaded the wrong map to the wrong title. All maps have the correct name in the file you download so just check that first please.
Klinck :D
This sticky is for listing .hex maps and PCIII maps for use with TuneECU. Please give info of exactly what maps the bike is from/for. ie year, UK/Europe, US, Aussie ect. Mods such as Cans, Air Filter/Motobox and if it is a Akra map or standard map loaded in ECU. That is an important point!
For the .hex maps, is it is combined with a custom PCIII map. Individual cylinders ect. You get the idea. The more info on the map the better.
Remember though that you are downloading and using a map at your own risk!
Please keep talk of TuneECU to the Offical TuneECU thread.
viewtopic.php?t=12511&postdays=0&postorder=asc&start=0
SD_Throttle_Bodies_Diagram&systems PDF (courtesy of MrZ32)
https://dl.dropboxusercontent.com/u/866 ... 1-0001.pdf
PCIII Maps
My custom PCIII map
06 UK SD, Akra map, Motobox, Akra slip-ons, O2 Eliminators, NOT individual cylinders.
https://dl.dropboxusercontent.com/u/866 ... OTOBOX.djm
05SD_LeoVinceSBK_dbkiller.djm
https://dl.dropboxusercontent.com/u/866 ... killer.djm
05SD_StandardExhaust.djm
https://dl.dropboxusercontent.com/u/866 ... xhaust.djm
05SD_uk_akra_DBkillers.djm
https://dl.dropboxusercontent.com/u/866 ... illers.djm
05SD_uk_akra_no_dbkillers.djm
06SD Klinck_FullAkra_Moto_NoFlys_NoDBs
(this map was made with this map installed in ECU KM610AE0503D01Map.hex
https://dl.dropboxusercontent.com/u/866 ... 281%29.hex
https://dl.dropboxusercontent.com/u/866 ... _NoDBs.djm
06SD Klinck_FullAkra_Moto_NoFlys_DBsIn.djm
https://dl.dropboxusercontent.com/u/866 ... _DBsIn.djm
06SD_motobox_filter_akra_no_dbkiller.djm (courtesy of Klinck)
https://dl.dropbox.com/u/86688880/06SD_ ... killer.djm
05SD KTM66, Akra slip ons, SAS Removed, Flies and Shaft Removed, Motobox.
https://dl.dropboxusercontent.com/u/866 ... otobox.djm
07sd_euro_akra_no_dbkiller.djm
07sd_uk_akra_dbkillers.djm
07SDR_AkraEvoSlip_Motobox_SBV_StockECU.DJM
https://dl.dropboxusercontent.com/u/866 ... ockECU.DJM
08 U.S. Standard SD motobox, SAS removed, secondary flies removed, FMF Apex cans, O2 eliminators, No DB
08US_SD_MB_2ND_FLYS_REM_FMFApex_NoDB.djm
08sdr_uk_akra_dbkill_snorkel_removed.djm
https://dl.dropboxusercontent.com/u/866 ... emoved.djm
08SDR_uk_akra_dbkillers.djm
08SDR_UK_MHBox+Flies_AkraSlip_NoDB_AkraECU.djm (Courtesy of Shadethechangingman)
https://dl.dropboxusercontent.com/u/866 ... kraECU.djm
09SD_uk_AkraEvo-DNA_Akrabase.djm
https://dl.dropboxusercontent.com/u/866 ... vo-DNA.djm
09SD A-UK_Akra-Slip_MB_ArkaECU.DJM (courtesy of emuexport)
https://dl.dropboxusercontent.com/u/866 ... rkaECU.DJM
.HEX Maps for upload to ECU with TUneECU.
note these maps are not standard KTM maps but either combined KTM and custom PCIII map or a KTM map customised with TuneECU on dyno.
These first maps are Akra maps that have been smoothed out by James aka MrZ32. They are the safest maps to use as there is no danger of them being lean. This is what he wrote about what has been done to the maps in another thread.
"I have left the akra fuelling alone but turned the o2sensors off, set the 2ndry flies to stay open always(for those that leave them in, but removing the altogether is best), I have also changed the f-l switchover so that the l map only runs at idle... 3-4K surging cured and lifting off the throttle doesn't quite have the same abruptness"
06 Akra smoothened
https://dl.dropboxusercontent.com/u/866 ... thened.hex
07+ EU SD Akra Smoothened
07+ US SD Akra Smoothened
08-10 EU SDR Akra Smoothened
08-10 US SDR Akra Smoothened
07-08 US SD speedmotorrad's map
- 08 US spec standard Superduke, FMF Apex exhausts, CPR intake, RC8 stacks, 2nd flies and shafts removed, SAS blocked off, O2 eliminator. My F-L switch values are modified, as is timing under 3500, bottom end is much smoother, most of the jerkiness removed, but still pulls like crazy, 121hp and 75.5 torque"
https://www.dropbox.com/s/vityja1fz1dw0 ... d.hex?dl=0
New!!
James has just sent me some smoothed out maps for standard SD/R. Here is what he wrote about them.
here are the standard maps that are now smoothened, this will make the newbs very happy.
The FL switchover can be applied to most maps with great results in smoothness but once a dyno tune map is created, you are going to have to be aware that the map was never designed to have these modifications applied.
You will notice that a lot of maps have a lean spot below 3k rpm because of the FL swichover and no matter how much tuning is done it wont accurately fix this because the ecu is reading two completely different maps under certain conditions. By changing the FL switchover, you are effectively causing the bike to only read off one map at any usable rpm (which your dyno tuner will thank you for later on) but will revert to the closed loop cycle at idle (to allow better running at idle).
06 SD standard smoothened.hex
07 SD Euro standard smoothened.hex
08 SD US standard smoothened.hex
08 SDR Euro standard smoothened.hex
These maps are custom maps and as such were created for a specific bike on the dyno. They carry a risk as your bike, even if the same and with the same mods could run lean and you should be aware of this before using them.
06 SD,EU Klincks Map. Full Akra, Motobox, 2nd flys removed, baffles out. made 129hp on dyno :D
https://dl.dropboxusercontent.com/u/866 ... d_NoDB.hex
06 SD EU, Klincks Map. Full Akra, Motobox, 2nd flys removed, baffles in. made 127 on dyno :D
https://dl.dropboxusercontent.com/u/866 ... affles.hex
06 SD,EU Klincks Map. Full Akra, Motobox, 2nd flys removed, baffles out plus ignition advance (ignition advance added after dyno so no figures available)
06SD EU Bash's Map. Based on KTMs D03 Map. Akro round, No Baffles, Second Flies out, RC8 Inlets, Cooler plugs, CRG Box, Modified Breather, Ignition Advance but runs 95 fuel.
https://dl.dropboxusercontent.com/u/866 ... ojex12.hex
07 SD, Motobox, Moto secondary files, SAS removed, 97-98 ron fuel. Rallsy's Map
https://dl.dropboxusercontent.com/u/866 ... ai_off.hex
08 SD GuysCustom most suited to aftermarket air filter (not airbox).hex
https://dl.dropboxusercontent.com/u/866 ... irbox_.hex
08 akra map with klinks pc111 map.hex (so Akra slip, Motobox, Hooligan SBV)
https://dl.dropboxusercontent.com/u/866 ... 11_map.hex
08 SD Grim990 low alt.hex (need more info if possible please!)
https://dl.dropboxusercontent.com/u/866 ... ow_alt.hex
08 SDGuysCustom possibly the best map for aftermarket pipes .hex
https://dl.dropboxusercontent.com/u/866 ... pipes_.hex
08 SD james' map for grim and motobox modified from rallsy's info.hex
https://dl.dropboxusercontent.com/u/866 ... s_info.hex
05_06 Klinck_Moto_Akra_map.hex
08 SDR Shade fuel - Otto ignition - motobox - flies - pipes.hex (meant to be an awesome map)
https://dl.dropboxusercontent.com/u/866 ... _pipes.hex
09SD_AkraEvo_MB_FliesRemoved.hex Nigel's map aka Fuel. (Warning** this map has large amounts of ignition advance. This map is individualised for this bike only,and may not be suited for your bike even with the same mods. If any abnormal noise occurs, switch off immediately as detonation can grenade an engine or best case bend valves. Do not use with any sub standard fuel.
Race fuel recommended)
https://dl.dropboxusercontent.com/u/866 ... emoved.hex
Links to cable parts UK
http://www.beatthegarage.com/product/00 ... _vag_com_/
http://www.beatthegarage.com/product/02 ... er_cable_/
http://cgi.ebay.co.uk/Japanese-Sumitomo ... 230839fe0a
Last edited by Colonel_Klinck on Mon Jan 10, 2011 11:05 pm, edited 12 times in total.
MrZ32
Postby MrZ32 » Tue Nov 30, 2010 8:18 am
klink, if I send you some maps via email (what is your email if this is the case). Are you able to host these online somewhere?
Postby Colonel_Klinck » Tue Nov 30, 2010 8:24 am
MrZ32 wrote:klink, if I send you some maps via email (what is your email if this is the case). Are you able to host these online somewhere?
Yes I can host maps. If you have any please send them to email below. Need max amount of info please!!! craig.wiltshire"AT".me.com obviously replace the AT with@
fuel
Postby fuel » Tue Nov 30, 2010 9:47 am
I'll send you my PC3 custom map its for an 09 UK SD with Akra Evo's and DNA race filter. Its got o2 elimiators and no baffles.
Postby ktmguy » Tue Nov 30, 2010 11:41 am
Make sure you list both our names as autors on it James as it's a good one! :lol: :twisted: :wink:
MrZ32
Postby MrZ32 » Tue Nov 30, 2010 8:05 pm
well yes there are two versions, guys map and a richened version of his (seemed to work better for the grim box above 6k rpm)... i think guys map is the most powerful map if you have a good set of slip ons on but if you run a motobox im thinking that you may want to use an even richer version of the one that i am running
(i suspect that because the grim990 box is smaller than the motobox, the motobox can flow more air)
MrZ32
Postby MrZ32 » Tue Nov 30, 2010 8:07 pm
the only thing i played with also is where the F-L switch cuts in
Postby Colonel_Klinck » Tue Nov 30, 2010 10:18 pm
Guys when you email me any PCIII or .hex maps can you please give me all info about what bike that map is from. Year? Cans? Any airfiler/box mods? Secondary butterflies? Makes my life a bit easier and means people get more info about exactly what they are downloading. More info the better.
Cheers :D
MrZ32
Postby MrZ32 » Tue Nov 30, 2010 11:11 pm
you forgot to put the hex up that has my name... the richer version of guys map, more suited to an airbox replacement with pipes etc...
Postby Colonel_Klinck » Tue Nov 30, 2010 11:33 pm
MrZ32 wrote:you forgot to put the hex up that has my name... the richer version of guys map, more suited to an airbox replacement with pipes etc...
Opps didn't scroll down the attachments window :oops: :oops:
Reb
Postby Reb » Wed Dec 01, 2010 1:09 am
OK, dummies question. What software do I need to open hex files. :oops:
Scooters are for Men who want to ride motorcycles, but prefer the wind on their vagina.
MrZ32
Postby MrZ32 » Wed Dec 01, 2010 1:31 am
tuneECU to open the.hex files
MrZ32
Postby MrZ32 » Tue Dec 07, 2010 11:07 am
by the way, the james' map is a fettled with version of guys map (richer, and other bits a lil fiddled with)
Postby Colonel_Klinck » Tue Dec 07, 2010 11:27 am
My 05/06 Akra, Motobox .hex map is now added above.
rallsy
Postby rallsy » Thu Dec 09, 2010 3:34 pm
would this map 08 akra map with klinks pc111 map.hex (so Akra slip, Motobox, Hooligan SBV)
with mine which is an
07 with akra slip,motobox, moto second butterflies, sas removed and o2 sensor blocks
thanks
MrZ32
Postby MrZ32 » Thu Dec 09, 2010 8:33 pm
yes it does work... better than the normal akra map but if you use good fuel try my one
Postby ktmguy » Fri Dec 10, 2010 10:14 am
rallsy wrote:would this map 08 akra map with klinks pc111 map.hex (so Akra slip, Motobox, Hooligan SBV)
thanks
Klincks map? You got me confused dude! Klincks bike is an 05-06 model I believe so you can't use his PCIII map on a 07 bike!
Use MrZ32 or my map for an 07-08 model!
rallsy
Postby rallsy » Fri Dec 10, 2010 10:33 am
ah i just looked at the combined files at the top of this thread and it said 08 akra moto box etc with klinks pcm map
hmm i was just looking see if one was already combined that would work with the 07 uk with motobox, sas removed, butterflies motohooligan
MrZ32
Postby MrZ32 » Fri Dec 10, 2010 11:35 am
guy,,, it is actually klinks pc111 map that i draped over an 08 akra map... it is pretty smooth and works well but our maps do work better... but if you didnt want to play with any advance settings that the klinks one would work.
I have used it and it ran better than the standard akra
but to make sure... it is the 08 klinks map... not the 06 one
emuexport
Postby emuexport » Thu Dec 16, 2010 11:54 pm
I have one for the following bike:
09 SD (AUS/UK)
Akrapovic slipons (no baffles)
O2 eliminators fitted
SAS Removed
Motobox fitted
Secondary Flies fitted
Akra map loaded on ECU
PCIII installed
Only mapped for one cylinder not both individually.
Anyone want it?
MrZ32
Postby MrZ32 » Fri Dec 17, 2010 1:19 am
emuexport wrote:I have one for the following bike:
09 SD
Motobox fitted
PCIII installed
Anyone want it?
i would like to see that map actually... just to compare
Postby Colonel_Klinck » Fri Dec 17, 2010 8:27 am
09 SD (AUS/UK)
Motobox fitted
PCIII installed
Anyone want it?
either post up a link to it or email me it and i'll add it to the list craig.wiltshire"at"mac.com
Edit: added to list :D
postalman
Postby postalman » Mon Dec 20, 2010 7:28 pm
Q: what map to start from?
I just installed the MH full kit. So my bike is now:
2007 SD, USA
Akra Ti round slip-ons, no baffle inserts
MH airbox, SBV, SAS delete
Presently on the Akra map, (eta) just test rode it. In 50 degree weather, it seems pretty darn good.
Fuel: 'premium' here is 92 AKI, sometimes 93 AKI, 10% ethanol. So AFAIK we have 96-97 RON here.
http://en.wikipedia.org/wiki/Octane_rating
I see in the Map Info the 'james' map says 'for 98 RON'. So is the 'klinks' map a better starting point, given the above? Or is that for EU 98 RON as well?
TIA
postal
Postby ktmguy » Tue Dec 21, 2010 3:01 am
postalman wrote:Q: what map to start from?
2007 SD, USA
TIA
postal
Try guy's map. Should be ok
MrZ32
Postby MrZ32 » Tue Dec 21, 2010 6:40 am
2007 SD, USA
TIA
postal
i would actually want to try the 08 version of klinks map first, as it is still rich but no advance (advance if wrong will cause serious probs quickly)
if that is ok then I would try dropping guys ignition settings into klinks 08 map, then I would try mine then guys. Guys will produce the most power no doubt guy... but I worry that it may be too lean for the motobox. I could be completely wrong and yours could be fine but I would prefer to be safe.
