.HEX Maps for TuneECU and Custom PCIII Maps Downloads
druu
Re: .HEX Maps for TuneECU and Custom PCIII Maps Downloads
Postby druu » Fri May 11, 2018 11:16 am
jambox wrote:
druu wrote:I posted in the other thread but figure I'd post here too:
Thanks in advance!
PM me your email and I'll sent you a couple of maps to try.
Some on here have used mine in the past with some good results.
PM'd!
sam46
Postby sam46 » Wed May 16, 2018 6:47 pm
Any fresh links to this map - 08 SDGuysCustom possibly the best map for aftermarket pipes .hex
Link on the first page is dead :(
Also after recommendations for this setup (for when i finish mods)
07 EU SD
Akro Evos
Ramair pods (guessing these are rotty equivelent or close)
2nd flies removed
07 SD 990 - Akros - Awaiting major mods
05 SD 990 - RamAir pods - Akro Ti - Sold
07 SD 990 - Superduke heaven RIP
KTM 250SXF, KTM 300EXC, KTM 450SMR, CRF450, KTM 250XCF, YZF R1 09, YZF R1 03, YZF R6 02, YZF R1 98
Postby Aphex » Wed May 16, 2018 10:09 pm
sam46 wrote:Any fresh links to this map - 08 SDGuysCustom possibly the best map for aftermarket pipes .hex
07 EU SD
Akro Evos
2nd flies removed
Here is a link to my google drive where the maps are hosted: https://drive.google.com/drive/folders/ ... sp=sharing
The map youre looking for is in the TuneECUmaps.zip file. Just download it and unzip it.
sam46
Postby sam46 » Thu May 17, 2018 10:25 am
Tidy cheers boss
Postby Aphex » Thu May 17, 2018 2:29 pm
sam46 wrote:Tidy cheers boss
One day I'll rehost the individual maps and sort out the front page of this thread.
jambox
Postby jambox » Fri May 18, 2018 7:54 am
druu wrote:
PM'd!
Sorry for the delay. I've sent them to you.
Tyler Durden
Postby Tyler Durden » Mon Sep 10, 2018 12:14 pm
Is it ok to flash my 2005 Super Duke with maps labelled 2006?
I have a completely stock bike that I am looking for a smoothened map to flash with TuneECU.
Thanks
Postby nampus » Mon Sep 10, 2018 7:56 pm
You should be fine with the 06 maps. 05/06 was the same bike.
07 onwards is different.
Tyler Durden
Postby Tyler Durden » Wed Sep 12, 2018 12:14 pm
nampus wrote:You should be fine with the 06 maps. 05/06 was the same bike.
Thanks.
I've just read the current ECU on my bike and found it to have the KM610EU050E001Map which I believe to be the standard KTM map. I'm planning on mapping it with the 06_SD_standard_smoothened.hex found in the Zip file hosted by Aphex.
Has anyone else done this?
Tyler Durden
Postby Tyler Durden » Wed Sep 12, 2018 1:09 pm
I have now looked into the differences between the stadrad and the smoothened maps (at least for my Standard 06 bike), and the differences are only seen in the 2nd Throttle table and the F-L Switch Table.
Can anyone shed some light on what the smoothened maps are effectively doing?
Postby No. 47 » Wed Sep 12, 2018 1:33 pm
As CK said in this first post:
These first maps are Akra maps that have been smoothed out by James aka MrZ32. They are the safest maps to use as there is no danger of them being lean. This is what he wrote about what has been done to the maps in another thread.
"I have left the akra fuelling alone but turned the o2sensors off, set the 2ndry flies to stay open always(for those that leave them in, but removing the altogether is best), I have also changed the f-l switchover so that the l map only runs at idle... 3-4K surging cured and lifting off the throttle doesn't quite have the same abruptness"
Tyler Durden
Postby Tyler Durden » Wed Sep 12, 2018 6:36 pm
Thanks for that.
I wasn't talking about the Akra maps, but I assume the same goes for the Standard maps too.
jambox
Postby jambox » Sun Sep 23, 2018 6:23 pm
Tyler, what mods have you got?
Tyler Durden
Postby Tyler Durden » Tue Oct 09, 2018 12:05 pm
jambox wrote:Tyler, what mods have you got?
At the time of typing my initial post I didn't have any mods.
I have since removed the SAS and fitted a straight through exhaust like the Akra.
I am going to flash the 06_Akra_slip_on_smoothened.hex would that be right?
jambox
Postby jambox » Tue Oct 09, 2018 12:37 pm
Yeah that'll be a good one to go for.
Sent from my EML-L09 using Tapatalk
Tyler Durden
Postby Tyler Durden » Tue Oct 09, 2018 12:42 pm
jambox wrote:Yeah that'll be a good one to go for.
Thanks.
I'm confused about whether I need to tick, or untick any of these devices within TuneECU prior to downloading the map to the bike.
SAI
O2 Sensor
2nd Throttle
Idle
Speed Control
EPC
jambox
Postby jambox » Tue Oct 09, 2018 1:46 pm
You don't want SAI (that's the SAS) or O2 sensors.
2nd throttle is the secondary flies, the smoothed map will keep them open, but if you untick it'll stop them moving.
Tyler Durden
Postby Tyler Durden » Tue Oct 09, 2018 6:26 pm
I went with this
SAI - Unchecked
O2 Sensor - Unchecked
2nd Throttle - Checked
Idle - Checked
EPC - Unchecked
I also increased the Rev Limit to 9900
jambox
Postby jambox » Wed Oct 10, 2018 7:29 am
Oh yeah forgot the EPC.
Yeah that's what you ticked/unticked.
Raising the revs is also a good shout (think that's where I put mine to as well). There was people running into problems going over 10k, but set at 9900 I never felt the need for higher.
Hope you feel contempt with the map, it might smell a little fuely, but you'll be pleased with the difference.
Tyler Durden
Postby Tyler Durden » Mon Mar 11, 2019 9:54 am
Having done some mods over winter.....
Whats the best TuneECU map for a 2005 Superduke with ITG filter, SAS delete and Akropovic Exhaust?
Postby Sarasota_Steve » Tue Mar 12, 2019 2:28 am
Please Tyler, don’t ask the same question twice in different threads.
You get to be a big boy and choose your own map. http://www.tuneecu.com/KTM_Tune_list.html
jambox
Postby jambox » Sat Mar 16, 2019 8:14 pm
Tyler Durden wrote:Having done some mods over winter.....
PM me your email address and I'll send you a few to try.
I had an 06 with Leo's and a Rottweiler.
