Oil Change SuperDuke 2007
denisimb
Postby denisimb » Sat Mar 24, 2012 12:06 am
Hello,
I did an oil change myself for my SuperDuke 2007. I bought this kit KTM Part Number: 00050000065
http://www.ktmtwins.com/ktm-950-990-lc8 ... filter-kit
In the kit, there was the filter, screen and new seal. However, after finishing installing all the part, I still have one Copper Seal Ring. I have install a new one on both drain plug (bottom of the engine and the oil tank). I am not sure where It goes. Do you have any advice?
Also, as per the oil screen (the one in the oil tank) does it have a special position to put it?
Thank you very much for the advice, and if you have other advice about oil change let me know!
Thank you
Re: Oil Change SuperDuke 2007
Postby SDNerd » Sat Mar 24, 2012 12:29 am
Hmmmm ... as that kit is somewhat "generic", maybe that extra copper 'seal' may be needed for another model (?). As far as I know, you installed the only 2 needed SuperDuke replacement 'seals'.
Not sure I understand the part about the oil tank screen ... Put the tank oil screen back the same as it was. As long as the screen basket is up in the tank (no other way to install it really ...) - you're good. The (axial) orientation of the screen doesn't matter.
denisimb
Postby denisimb » Sat Mar 24, 2012 1:42 am
Hi SDnerd,
Thank you for you quick reply.
This is OEM kit from KTM for oil service.
As per the oil screen, you got it, I was curious about the orientation.
Thank
Postby SDNerd » Sat Mar 24, 2012 4:55 pm
denisimb wrote:This is OEM kit from KTM for oil service.
Yep - I use the same one. :)
As there are a few variations of the LC8, its the only explanation I can think of for the extra ring. :?:
Faltenhals
Postby Faltenhals » Sun Mar 25, 2012 12:49 am
The extra ring is for the cluch oil jet .. For the screw which is closing the hole..
motorbreath
Postby motorbreath » Fri Apr 06, 2012 2:35 pm
Make sure when you put the copper washers back on the bolts that you install the chamfer the correct way.
Postby SDNerd » Fri Apr 06, 2012 3:46 pm
Faltenhals wrote:The extra ring is for the cluch oil jet .. For the screw which is closing the hole..
No shit - good to know!I can't recall at the moment, but the extra washer seemed to big for that - will confirm at next change. Thanks!
