Bike won't start FI light steady
aerosolfarmer
Newbie
Postby aerosolfarmer » Tue Apr 24, 2012 12:52 am
While riding on my second tank of gas my bike fi light flashed then the bike died. It acted like the battery was dead. the gauge ect all went blank. Got back to the shop and found the battery quite lively. I cleaned everything up now the FI light is on steady and the bike does not start. the fuel pump isn''''t pressurizing or anything.
like I said its on the second tank after putting on a yoshi exhaust. Motohooligan airbox flies sas removed. has O2 sensors eliminated not with tuneecu but with the plugs with wire resistors (bought triumph ones).
AGRO!
Re: Bike won't start FI light steady
Postby AGRO! » Tue Apr 24, 2012 1:43 am
Sounds to me like the fuel pump has crapped itself. When you turn the key to on can you hear the fuel pump?
If not it could be dead.
Also have you ever cleaned and lubed the big grey plug on right hand side up under the fuel tank? This plug can cause trouble also.
aerosolfarmer
Newbie
Postby aerosolfarmer » Tue Apr 24, 2012 2:02 am
No I'll try to lube em. going to the shop now.
