Aftermarket Regulator Rectifier
cdlabate
Postby cdlabate » Wed Nov 07, 2012 4:47 am
Has anybody installed this http://www.regulatorrectifier.com/catal ... -Rectifier If you did, what did you do with the now open white plug after install?
:wink:
cdlabate
Re: Aftermarket Regulator Rectifier
Postby cdlabate » Sat Nov 10, 2012 3:04 am
Bueller...
:wink:
Grendel
Postby Grendel » Sat Nov 10, 2012 3:17 am
Since the unit gets power directly from the battery, Grendel taped it up and left it alone. Both wires in the plug are positive. Grendel assumes they did this rather than run a heavier gage wire to feed the original regulator power. Since it is positive, just make sure it is well insulated.
Grrrrrrrr..... . . . .
cdlabate
Postby cdlabate » Sat Nov 10, 2012 3:55 am
Grendel wrote:Since the unit gets power directly from the battery, Grendel taped it up and left it alone. Both wires in the plug are positive. Grendel assumes they did this rather than run a heavier gage wire to feed the original regulator power. Since it is positive, just make sure it is well insulated.
Easy enough. Thank you.
:wink:
omky756
Postby omky756 » Sat Nov 10, 2012 4:09 am
Those mosfet regs are calling to me...
Not that I need one..yet...
I still have a spare used reg. in my drawer..
:wink:
Where you been Grendel..????
Hunkered down in a patch o green bud
spice.???
Lol
8)
Stratkat
Postby Stratkat » Tue Nov 20, 2012 3:28 pm
what is the white plug you are referring to? is it on the SD harness?
is this aftermarket unit a plug and play? my stock unit failed and im not sure to replace it with a stock one.
cdlabate
Postby cdlabate » Wed Nov 21, 2012 4:13 pm
Stratkat wrote:what is the white plug you are referring to? is it on the SD harness?
The white plug that is directly connected to the stock R/R.
:wink:
Stratkat
Postby Stratkat » Wed Nov 21, 2012 5:45 pm
so it doesnt plug into the aftermarker R/R?
Grendel
Postby Grendel » Wed Nov 21, 2012 6:44 pm
There are three items coming out of the new regulator/rectifier. Positive and negative go directly to the battery. This is a change from the oem unit which pulls positive power from the wiring harness. The three wire regulator harness is a direct plug in to the harness.
so live
Postby so live » Tue Jul 09, 2013 6:16 pm
You guys having good luck with this regulator/rectifier?
Any others to look at?
Thanks!
cdlabate
Postby cdlabate » Tue Jul 09, 2013 7:38 pm
so live wrote:You guys having good luck with this regulator/rectifier?
Thanks!
So far so good! My bike hasn't left me stranded anywhere and starts up every time.
:wink:
so live
Postby so live » Wed Jul 10, 2013 6:29 pm
Kick ass! I measured about 13 volts at ~5k rpms so I'm thinking I need one of these. I want to set up my data logger to record system voltage so I can see what it's doing under load.
stinky
Postby stinky » Tue Apr 05, 2016 12:22 pm
just had a wire snap off from the regulator. Its a fat black wire and has 2 green wires inside it. it looked like it was located at the negative battery terminal but before i reconnect can anyone just confirm this for me?
what is this cable and where does it connect to
thanks all
Postby No. 47 » Tue Apr 05, 2016 3:49 pm
The Mosfet looks like this...............
...............so you must have the OE item for which, yes, the two green cables within the black plastic sleeve are attached to the battery negative as per the wiring diagrams in the repair manual downloadable from here............
LiferLance990
Postby LiferLance990 » Tue Sep 20, 2016 9:19 pm
My brown plug is all melted up... Anyone know where I can order both sides of that plug?
2007 Super Duke
Akra Evo w/o baffles
Evap removed
Akra Smooth map
Battlax BT003s
Top Block Sliders
Postby No. 47 » Tue Sep 20, 2016 9:45 pm
From KTM - OEM part nos. here viewtopic.php?f=18&t=16897 under Spare Connectors fiche or, possibly, cheaper here http://easternbeaver.com/Main/Elec__Pro ... ctors.html - drop Jim, US ex-pat in Japan, a line, always been very helpful to me.
superxsive
Postby superxsive » Tue Sep 20, 2016 11:54 pm
If you are interested I have a new, never used unit for sale. $125.
This is the unit.
2007 KTM Superduke 990 stock.
1977 Yamaha xs850 to 900cc cafe racer.
Reaper
Postby Reaper » Sun Oct 02, 2016 5:53 pm
Ive got one off a BMW, changing all the connectors too. Will post pics when I do it
Users browsing this forum: Majestic-12 [Bot] and 2 guests
