LC8 Timing chains replacement walkthrough?
Postby Colonel_Klinck » Wed Apr 17, 2013 5:12 pm
Hey guys, I have to have my engine out again in a couple of weeks :roll: Both base gaskets are weeping again :evil: Scrutineering picked it up at the last race and although they let me carry on they want it fixed before the next race. Going to use some uber gasket sealer a buddy uses on diesel agricultural engines. If that shit doesn't stop it nothing will! While I'm in there I'm going to swap the timing chains. She has done 50k hard miles now and its seems sensible to do it. One snapping isn't worth considering and would probably take the whole engine with it. However although I am more than comfortable removing the cylinders, removing everything to get to the balancer shaft so I can replace the chains is slightly more scary. The repair manual is ok but if anyone knows of a really good walkthrough I would be uber grateful. If I can't find anything I will try and photograph every stage and do a walkthrough. Might be difficult to capture the nervousness and copious amounts of swearing however.
Superdan
Thunder pumpkin rider
Re: LC8 Timing chains replacement walkthrough?
Postby Superdan » Wed Apr 17, 2013 5:26 pm
Good luck dude!
I think Jody was mentioning doing this too, saw a reply saying some washers needed changing too? (sorry if im teaching you to suck eggs).
Why do you think its still weeping? Is there anything you wish you changed but had not?
Postby No. 47 » Wed Apr 17, 2013 7:38 pm
Give Paul a ring - he also has a suggestion re 'reinforcing' the base gasket - at 60k+ miles, mine's pissing out from both front and rear.
Silverbear
Postby Silverbear » Thu Apr 18, 2013 12:33 pm
Colonel_Klinck wrote:Hey guys, I have to have my engine out again in a couple of weeks :roll: Both base gaskets are weeping again :evil: Scrutineering picked it up at the last race and although they let me carry on they want it fixed before the next race. Going to use some uber gasket sealer a buddy uses on diesel agricultural engines. If that shit doesn't stop it nothing will! While I'm in there I'm going to swap the timing chains. She has done 50k hard miles now and its seems sensible to do it. One snapping isn't worth considering and would probably take the whole engine with it. However although I am more than comfortable removing the cylinders, removing everything to get to the balancer shaft so I can replace the chains is slightly more scary. The repair manual is ok but if anyone knows of a really good walkthrough I would be uber grateful. If I can't find anything I will try and photograph every stage and do a walkthrough. Might be difficult to capture the nervousness and copious amounts of swearing however.
Klinck,I would do a simple test if I were you.Go get a cheap vacuum boost gauge[used on turbo motors] and tee into your crankcase breather tube.Go for a ride and give the bike a good thrashing and check if the vacuum is pos or neg.It should be reading zero or a touch pos.Too much positive pressure and your gaskets will leak.You want negative pressure ideally.What breather mod are you running?Cheers.
kevxtx
Postby kevxtx » Fri Apr 19, 2013 6:15 am
+1
Postby Colonel_Klinck » Fri Apr 19, 2013 7:43 am
I have the breather back into the motobox. Has to be a closed system like that for racing. Before I had the basic breather mod. Will do this. You think something like this will do it?
http://www.halfords.com/webapp/wcs/stor ... &langId=-1
DougFir
Postby DougFir » Sat Apr 20, 2013 3:04 pm
Lot of info on the LC8 base gasket in the AVDrider.com forum but it might be a buzz kill for C K. :mrgreen: :mrgreen:
Postby Colonel_Klinck » Sat Apr 20, 2013 3:18 pm
DougFir wrote:Lot of info on the LC8 base gasket in the AVDrider.com forum but it might be a buzz kill for C K. :mrgreen: :mrgreen:
Already been, posted and been pointed at a walk through dude. Such a good forum.
