What am I about to do? FINALLY DONE! Pics.
nitro450exp
Postby nitro450exp » Mon Aug 03, 2015 8:39 am
Well the parts are trickling in.
Some prep pictures.
I have sprayed in a professional booth before, but this will be a real backyard
adventure, with 2K cans of primer and topcoat.
Wish me luck.
Nitro
Pre scuff and chip repair.
Post scuff and chip repair, masked for 2K primer.
2006 KTM Super Duke LC8
2000 Honda RVT1000RR (SP1, RC51)
2009 Aprilia Tuono 1000R
WERA # 661 (Retired)
WERA Endurance # 66 (Retired)
nitro450exp
Re: What am I about to do?
Postby nitro450exp » Thu Aug 06, 2015 8:45 am
2007 Lower profile pump has arrived.
Quick connect coupler is broken, will reuse '06 one.
just waiting on 3M fine line tape and fuel sensor (used) and then the fun begins.
Have:
Tank (2007 used black)
Inner shields (New)
Pump (2007 Used)
zip ties (KTM M6 plug type for sensor harness)
All hardware (2006 tank)
Fairings (Ti 2006 will be modified to fit )
Ti 2K aerosol Paint (GM WA529F Dark Bronze Metallic )
2K aerosol Primer
Paint prep and supplies.
Need:
3mm 3M fine line tape (Mask off original black center section and tank pad)
2007 Fuel sensor (used) orientation is 90 Deg from 2006 type.
Place to paint. I have no garage as I rent an apartment in downtown Paris.
Fun and games to ensue.
I will probably paint it in the parking Garage at work, lighting is terrible but it is inside and should keep stuff out of the paint.
Nitro out
TimR
Postby TimR » Thu Aug 06, 2015 9:22 am
Good luck! :)
Is there going to be some orange?
Should be interesting - keep us posted with pictures
nitro450exp
Postby nitro450exp » Thu Aug 06, 2015 10:49 am
nitro450exp wrote:Fairings (Ti 2006 will be modified to fit )
No Orange , see above Ti = Titanium (GM WA529F Dark Bronze metallic)
Only orange is the KTM anodised Brake lids and clutch lid and Levers.
nitro
nitro450exp
Postby nitro450exp » Mon Aug 10, 2015 5:50 pm
Fine line taped.
Can anyone say primer?
Nitro
Postby SDNerd » Mon Aug 10, 2015 6:17 pm
Painting aside - I wouldn't screw around with the piece-of-shit OE "Quick connect coupler". They all will eventually break.
nitro450exp
Postby nitro450exp » Thu Aug 13, 2015 1:04 pm
It is going to be cooler and less humidity on Friday, I think I will finally paint.
Hope it goes well.
Nitro
Davo-Singapore
Postby Davo-Singapore » Fri Aug 14, 2015 3:04 am
nitro450exp wrote:It is going to be cooler and less humidity on Friday, I think I will finally paint.
Hope it goes well.
Nitro
Come on hurry up. The suspense is killing us all....
nitro450exp
Postby nitro450exp » Fri Aug 14, 2015 8:38 am
No just you Davo !
LOL
Nitro
cheeheese
Postby cheeheese » Fri Aug 14, 2015 8:46 am
I want to see this too...
nitro450exp
Postby nitro450exp » Fri Aug 14, 2015 9:40 am
The paint supplier did not send any tech data sheets with the order.
I am waiting for the info, I have sent several emails.
I need to know flash time, window time, final flash time and sand time.
Nitro
Postby ktmguy » Fri Aug 14, 2015 9:42 am
nitro450exp wrote:The paint supplier did not send any tech data sheets with the order.
Nitro
Pfff excuses! You can find all that info online now if you google it! :twisted:
nitro450exp
Postby nitro450exp » Fri Aug 14, 2015 12:56 pm
KTMGuy
I did google it, but came up with very wide range of times depending on manufacturer.
Flash times ranged from 2~3 Min all the way up to 20~30 min.
And Window time from 12 H to 48 H.
But that aside here Is the primer.
Once I know the sand time, I will feather the edge, retape and then after 12H hit it with the color.
Nitro out
Postby abc » Fri Aug 14, 2015 1:13 pm
nice job so far. Looking forward to see your results.
This stuff always takes a longtime to do especially if the person doing it doesn't have a direct line to the right industry people. My bellypan took a lot longer to do because I wanted to be careful so to get a reasonable result. I recon 30% of the total build time was spent chasing up and understanding the many produce tech spec sheets so everything had to be compatible and work together chemically.
Good job nitro. I hope you get a great result mate.
nitro450exp
Postby nitro450exp » Fri Aug 14, 2015 1:42 pm
:D
Nitro
nitro450exp
Postby nitro450exp » Fri Aug 14, 2015 3:57 pm
Titanium BABY !!! :D 8)
Nitro
nitro450exp
Postby nitro450exp » Fri Aug 14, 2015 5:56 pm
All done.
Let it cure for 2 weeks and buff.
Nitro
Postby Aphex » Fri Aug 14, 2015 6:03 pm
Looks great.
Postby SDNerd » Fri Aug 14, 2015 6:22 pm
Aphex wrote:Looks great.
+1
Buff? Looks OE already in the pics.
Want to spray mine?
omky756
Postby omky756 » Fri Aug 14, 2015 7:45 pm
+1
Want to spray mine?
Yours has that rode hard put away wet look...
Shoulda kept mine and just repaired it..
Never should of called my insurence company...
Pretty only lasts so long anyway..
For me..I have to see it put together to say I like it..
Remember..the pink one..??
Forgot the brudahs' handle..
Think his name is Stu.???
:lol:
8)
Postby SDNerd » Fri Aug 14, 2015 8:25 pm
omky756 wrote:Yours has that rode hard put away wet look...
:lol: "That's what she said ..."
:lol:
8)
Oh yeah - the pink framed one ... While you may have attempted to "replace" yours with "... more advanced technology ...", I can only agree that you shoulda kept it. You - of anyone here - coulda fixed it up nice. Wouldashouldacoulda. 8)
nitro450exp
Postby nitro450exp » Fri Aug 14, 2015 8:27 pm
SD
Sure pack it up and ship it to me in France.
Nitro
Postby ktmguy » Fri Aug 14, 2015 10:17 pm
Looking good!
Postby Sarasota_Steve » Sun Aug 16, 2015 2:51 pm
Looks good! Can't wait to see the bike back together
08 990 SDR
nitro450exp
Postby nitro450exp » Sun Aug 16, 2015 4:16 pm
SS
Bike is still in one piece and being ridden.
This is a large tank conversion.
That is why the color change
The later larger tank bikes (07-11) Were not offered in Titanium.
I will swap tanks this week shouldn't take more than a few hours.
Nitro
