USB Port for phone - GPS
Postby Sarasota_Steve » Mon May 09, 2016 7:53 pm
Hello,
Yesterday I installed a USB Port to charge the phone or supply power to the GPS. Very easy installation.
The dual port I bought is this one, paid $13.
I removed the inline fuse since the switched ACC1 connections are fused. It comes with a really long cable so you can connect it directly to the battery or if you want to go from the front of the bike to the space under the seat. I only needed around 30cm (2') of wire since I installed the port on the left black radiator cover with double stick tape.
This is the bracket where the port sits. You can remove the port when you need to take the radiator covers off.
Port installed
Wiring connections and routing
The red/yellow wire is positive, brown is negative.
You can see the dielectric grease oozing out of the transparent OEM connectors. The blue are the shrink blade terminal connectors that I used and shrunk them with my heat gun.
That's all. Easy. Useful. Simple. Cheap.
Jacko
Re: USB Port for phone - GPS
Postby Jacko » Tue May 10, 2016 9:26 am
whats the output of these?, i had a usb on my old bike but my iPhone on full brightness running maps would eat battery faster than it charged! got a more efficient phone, and app now so it shouldn't be an issue but id like as higher output as possible just incase
Postby Sarasota_Steve » Tue May 10, 2016 11:32 am
5 volts - 2.1 Amps
08 990 SDR
Superduke990R
Postby Superduke990R » Tue Jun 21, 2016 4:07 pm
I want to fit a 12V socket on my SD as well. Where did you take the switched ACC1 from? When the key is out there is no power?
Postby Sarasota_Steve » Tue Jun 21, 2016 4:40 pm
Behind the headlight.
Yes, when the key is off the power is off.
08 990 SDR
coyo
Postby coyo » Sun Jul 10, 2016 6:30 pm
Where did you get the USB from?
My (old) Garmin 550 is starting to act up so I've found myself using my iPhone for nav but I need to wire it up. I like how you did this.
Postby Sarasota_Steve » Sun Jul 10, 2016 7:33 pm
coyo wrote:Where did you get the USB from?
Coyo,
This is the Amazon link https://www.amazon.com/gp/product/B00NEJ46V8/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
And dang it. It's cheaper now than when I bought it in May '16.
coyo
Postby coyo » Mon Jul 11, 2016 4:07 pm
Thanks much. I was able to find the same one on Amazon.ca and will be ordering. :D
seamus dunn
Postby seamus dunn » Fri Jul 29, 2016 8:25 pm
Great pictures. I will be trying this myself soon.
07' Duke " Anthracite"
