Tune ECU driving me up the wall
Reaper
Postby Reaper » Sun Oct 30, 2016 5:36 pm
I can't get it to connect at all. Removed the software and downloaded it again. Downloaded the driver and made sure it's the one being used when the cables plugged in. Went through the order of connecting things go it says and tried a few different ways but it just won't connect.
Anyone got any ideas on how I can sort this? Need to stop the FI light flashing
Re: Tune ECU driving me up the wall
Postby bic_bicknell » Sun Oct 30, 2016 5:57 pm
I hate that fooking FI light. :wink:
Postby Aphex » Sun Oct 30, 2016 8:58 pm
Mine seems different everytime I connect it to the bike. Some times it works if I connect the cable to the laptop then the bike then start the program then turn the bike on. Some times its the reverse order. ¯\_(ツ)_/¯
Postby No. 47 » Mon Oct 31, 2016 9:51 am
Has it connected previously?
Reaper
Postby Reaper » Mon Oct 31, 2016 6:18 pm
Im sure I've connected it before but i could be wrong. The cable is a lonelec one
Postby DukeNukem999 » Tue Nov 01, 2016 8:05 am
I had this with a mates brand new Lonelec cable. I got mine and it worked straight away
2010 (white-frame) SD, Rotty intake / SAS removal, Ceramic coated OEM headers / Akra slipons, Ergo seat, Scott's oil filter, Factory alarm, SDR levers, Shorai LiFePO4, OEM 16T / KTM Supersprox 40T, RK GB525GXW chain, Michelin Pilot Road 4 / Pilot Power 3.
orpheus
Postby orpheus » Tue Nov 01, 2016 10:43 am
Are you loading the FTDI driver ?
Also are you following the setup guide on TuneECU website ?
Have you got the ignition on when trying to connect ?
I also seem to remember that I had to drop the speed of the inteface down abit but it was a few years ago that I set this up so can't really remember specifics.
Silverbear
Postby Silverbear » Tue Nov 01, 2016 12:44 pm
You get what you pay for.
Reaper
Postby Reaper » Tue Nov 01, 2016 12:55 pm
orpheus wrote:Are you loading the FTDI driver ?
Yep, I followed it all to the letter and installed the drivers it says.
orpheus
Postby orpheus » Tue Nov 01, 2016 4:42 pm
Are you running on laptop ? If so try with laptop connected to mains; power saving on some laptops has been known to cause issues with USB.
Also, not sure how good your bike battery is but maybe worth trying with charger plugged in as well; just to eliminate low voltage etc
If that doesn't work you could try an older / newer version of tuneECU software.
If you can't test on another KTM you could plug the cable into a car (older car but not pre ODBII) just to check if cable is working OK. You would need to find some ODBII sofware for this.
Reaper
Postby Reaper » Tue Nov 01, 2016 5:16 pm
Cheers for the tips, laptop was plugged into mains and the bike battery is fully charged and on a powermate.
Im getting the picture I've not missed anything stupid and that it must be a dodgey cable
orpheus
Postby orpheus » Thu Nov 03, 2016 10:51 am
Yes - sounds like cable...
You seem to have tried everything and I'm sure you would have got something out of it by now.
Reaper
Postby Reaper » Sat Nov 05, 2016 12:13 pm
Boom, got it working by using a different laptop. So basically for some strange reason it didn't like my dads laptop but did my sisters.
I know have the problem my ECU won't except the maps on here
Postby DukeNukem999 » Mon Nov 07, 2016 5:10 am
sounds like a driver related issue....maybe with the OS ?.
Vortex155
Postby Vortex155 » Wed Feb 08, 2017 4:28 pm
id driver related, search upon the tuneecu site for the FDTI driver link, dl it and install it, problem must be solved
Vortex155 on twitter
