Fitment of Battletwins bellypan
speedfiend41
Postby speedfiend41 » Thu Jul 06, 2017 2:31 am
I've got some race glass for the SDR and I'm just fitting the belly pan. Obviously the Superduke doesn't have mounting points for the rear of the belly pan as the original chin spoiler doesn't need them.
Any hints re securing the rear of the belly pan? I've had a squizz and there's nothing obvious - not even if I make a bracket...
Re: Fitment of Battletwins bellypan
Postby Aphex » Thu Jul 06, 2017 3:35 am
I think it's gonna be abit problematic because that thing is going to vibrate like a hitachi magic wand.
Postby Scotty » Thu Jul 06, 2017 5:35 am
My 990s both have bellypans on them and they're fixed at the rear with an aluminium bracket to the frame on either side - unfortunately both bikes are in storage ahead of a house move at the moment so I'm unable to photograph the fixings for you.
Postby RichUK » Thu Jul 06, 2017 7:22 am
The lower foot rest hanger bolt looks a likely target for a fixing.
Could even just use a length of bracket strip, or 2 sections of it.
I searched for "Exhaust Perforated Metal Strip Mounting Brackets"
and this sort of thing came up
speedfiend41
Postby speedfiend41 » Thu Jul 06, 2017 7:42 am
Cheers gents.
I reckon the footpeg brackets are the best choice. Not sure if I prefer the look of the chin spoiler over the belly pan, so this might be just for track use...
Postby No. 47 » Thu Jul 06, 2017 7:43 am
See here - viewtopic.php?f=8&t=20943&hilit=Bellypan - re Replicast bellypan rear mounts.
As standard, rhs fixing uses a long shallow z-profile bracket bolted to rearsets, just visible in photos - as standard, lhs fixing is to sidestand mount, assumed to be removed but can be same as rhs.
motoyoyo
Postby motoyoyo » Thu Jul 06, 2017 3:45 pm
I fitted an extra carbon heat shield to my S2R1000 exhaust with a couple special clamps made just for securing to exhaust pipes. They are very solid and should hold the belly pan on nice and tight at the rear just where the two exhaust headers are. They are kind of hard to find since coming up with the proper Google search term is sometimes a waste of time, but here is something I did find, http://www.elineaccessories.com/ecommer ... eld-1.html
2008 990 SDR US, Full Titanium Akro, Rottweiler Airbox, SAS Blockoff
speedfiend41
Postby speedfiend41 » Fri Jul 07, 2017 4:55 am
Thanks!! Very helpful.
Postby Scotty » Fri Jul 07, 2017 7:41 am
If you attach it to the exhaust pipes it will suffer a lot of vibration - I've yet to see any manufacturer mount bodywork to an exhaust system (though I wouldn't be surprised to see it on a Chinese bike...) That method may secure it initially but I wouldn't expect it to last long. :(
motoyoyo
Postby motoyoyo » Fri Jul 07, 2017 5:25 pm
I would suggest using a fiber heat washer or two at the exhaust clamp and maybe even rubber grommets on the bellypan sandwiched with a stainless washer on either side. Longer stainless bolts would probably be necessary too with red loctite. All this could be tried for relatively cheap and no visible brackets on the outside of the bellypan. I'm sure everyone has their own approach, but this is just another possible solution that I would look at.
