Slave cylinder ball bearing.
Postby Aphex » Thu Aug 03, 2017 2:56 am
Does anyone know the diameter of the ball bearing in the OEM slave? I know the Oberon unit uses an 8mm ball but some how the ball is missing from mine and you can only purchase the slave as a unit for $180.
crazyinp
Re: Slave cylinder ball bearing.
Postby crazyinp » Thu Aug 03, 2017 4:52 am
Oberon slave is $120 last I checked. Did you try to call them and ask if they would sell you the ball only?
______
In the Garage:
2015 KTM Superduke 1290R
2013 Ducati Panigale R
Postby Aphex » Thu Aug 03, 2017 2:15 pm
I've not tried calling them as I'd like to try and get a replacement before Saturday. I figure a balls is a ball is a ball so if I can get the size of the OEM ball then I can get one from a local shop.
It looks like the OEM slave uses a 7mm ball, anyone correct me if I'm wrong.
Postby Sarasota_Steve » Thu Aug 03, 2017 6:07 pm
Aphex wrote: ... I figure a balls is a ball is a ball so if I can get the size of the ball then I can get one ...
That's what she said .... :P
08 990 SDR
crazyinp
Postby crazyinp » Thu Aug 03, 2017 8:08 pm
Aphex wrote:I've not tried calling them as I'd like to try and get a replacement before Saturday. I figure a balls is a ball is a ball so if I can get the size of the OEM ball then I can get one from a local shop.
Meant give them a call and they should be able to answer you.
______
In the Garage:
Postby Aphex » Fri Aug 04, 2017 12:38 am
Tried that and they said they would email me the specs. I went to mcfaddendale and picked up a couple bearing balls in different diameters.
Postby Aphex » Fri Aug 04, 2017 4:25 am
Sorted it with a 9/32 steel ball.
crazyinp
Postby crazyinp » Fri Aug 04, 2017 5:03 am
that is not very good customer service....
______
In the Garage:
