Slipper Clutch
Vortex155
Slipper Clutch
Postby Vortex155 » Thu Apr 19, 2012 2:03 pm
Have ordered the TSS slipper clutch, anybody got experience with installing slipper clutches here.
Downloaded 2 really good youtube tutorials bout slipper clutch installation on a Honda cbr600.
Read some stuff regarding the subject...one of the things that I found out was the use or not use of the judder springs...there are some lines found of not using this into a slipper becuz this will break down to easy.
By asking I try to do as much homework before I start off with the job.
Bought the clutch holding tool and a moment wrench form 40-200Nm, the RC8 clutch needs to be torqued at 130Nm.
Vortex155 on twitter
scandinavian flick
Re: Slipper Clutch
Postby scandinavian flick » Sun Apr 22, 2012 6:10 pm
Hi Mate I'm going down the TSS/SIGMA/YOYO route soon, I've done alot of reading up but you mention "judder springs" whats that all about? I will probably get mine from Sigma £620 all in with the suzi k5 springs... Please tell me more!! :?:
Vortex155
Re: Slipper Clutch
Postby Vortex155 » Sun Apr 22, 2012 9:23 pm
they sit here
not a ktm clutch this pic
Vortex155
Re: Slipper Clutch
Postby Vortex155 » Sun Apr 22, 2012 9:28 pm
in the LC8 they sit closed at the engine...but there are lines I've found to put them on 3th position and there's even a race team that have removed them, so this really important to have this right when you and I start off.
I paid 'bout the same for the TSS, they're both the same also.
Only the sigma was a bit more expensive here...750£/800€
btw if you search on youtube you'll find a good how to bout slipper clutch, the model is a honda 600 and its a yoyo, work is the same.
Share your experiences here,
you show yours, I'll show mines :wink:
kevxtx
Re: Slipper Clutch
Postby kevxtx » Sun Apr 22, 2012 10:04 pm
Both rings are removed when installing the slipper clutch.
Vortex155
Re: Slipper Clutch
Postby Vortex155 » Mon Apr 23, 2012 8:12 am
was looking in the SD slipper clutch tutorial indeed no word on fitting the judders back in
http://www.superduke.net/forum/viewtopic.php?t=11308
but found others that mention placing it in 3th position
other that race have total destroyed their engine becuz the judder blew to pieces onbaord a 675
http://www.triumph675.net/forum/showthread.php?t=5191
so indeed better let it out, thx kevxtx
for reply
Vortex155
Re: Slipper Clutch
Postby Vortex155 » Mon Apr 23, 2012 8:30 am
This is a pic of RC8 2009 clucth
it sits at first sport name is diff belleville springs are they called here
Vortex155
Re: Slipper Clutch
Postby Vortex155 » Mon Apr 23, 2012 8:34 am
Scandinavian, FatTony has a topic on tech manuals upon ktm forum uk, found most of the pdf's there.
kevxtx
Re: Slipper Clutch
Postby kevxtx » Mon Apr 23, 2012 11:25 am
If you leave them in it will effect the slipper clutch action & will ware out the small clutch plate.
scandinavian flick
Re: Slipper Clutch
Postby scandinavian flick » Mon Apr 23, 2012 5:23 pm
Hi Guys, you've probably seen this but thought it worthwhile posting up...
http://www.slipperclutchs.com/?menu=pro ... n&montaz=1
kevxtx
Re: Slipper Clutch
Postby kevxtx » Mon Apr 23, 2012 11:06 pm
STM say remove the rings in their fitting instructions.
I can see why they say that, the rings act as a mini pressure plate that seperates the clutch pack at the small plate when the clutch is engaged, if the slipper disengages the clutch pack to slip the clutch the mini pressure plate rings could effect the timing of the slip.
Mine was taken out with my slipper & have had no dramas.
Vortex155
Re: Slipper Clutch
Postby Vortex155 » Fri Apr 27, 2012 1:26 pm
kevxtx wrote:STM say remove the rings in their fitting instructions.
and no problems finding neutral afterwards?
Maybe I also go for the no judder option.
Got to pickup my slipper this evening.
Vortex155
Re: Slipper Clutch
Postby Vortex155 » Sat Apr 28, 2012 8:24 am
If you leave that judder plate and springs out...don't have this to be replaced with another clutch plate becuz there will be less stack height.
Think I better wait for installing before I have an answer on this, shall search for the stm manual, read what's stated there.
Meanwhile you may always set me in the right direction off course :wink:
Vortex155
Re: Slipper Clutch
Postby Vortex155 » Sat Apr 28, 2012 10:28 am
This is the TSS package that arrived yesterday
scandinavian flick
Re: Slipper Clutch
Postby scandinavian flick » Sat Apr 28, 2012 1:08 pm
Looking good.. Keep the pics coming, anymore news on the judder springs?
Vortex155
Re: Slipper Clutch
Postby Vortex155 » Sat Apr 28, 2012 4:08 pm
I put them back in becuz I aint got spare plates.
But i put them in 2nd or even 3th position.
....but i've other problems at this moment, stupid bolt that sit on standard basket doesn't come lose :?
believe me tried it all...seems its welded together or something.
bolt doesn't come out and already put more then 200Nm on it.
Vortex155
Re: Slipper Clutch
Postby Vortex155 » Sat Apr 28, 2012 7:20 pm
My attempts where useless today bolt stayed stuck
have to find another tool for gripping upon the basket
Vortex155
Re: Slipper Clutch
Postby Vortex155 » Sat Apr 28, 2012 8:31 pm
a tool like this
kevxtx
Re: Slipper Clutch
Postby kevxtx » Sun Apr 29, 2012 6:53 am
No problem at all finding neutral, I run 10w 60 oil. Both rings removed & still have the small clutch plate in place.
Vortex155
Re: Slipper Clutch
Postby Vortex155 » Sun Apr 29, 2012 9:09 am
Okay thx Kev for the info.
But ran into major trouble while performing the art of bolt removing. I better had stopped all efforts and went to dealers, becuz that bolt wouldn't let go and the use of a pneumatic torch wrist was required, bike is fooked now :x
broke two teeth of the outer outer clutch basket so that needs replacement also now...bugger :?
Vortex155
Re: Slipper Clutch
Postby Vortex155 » Sun Apr 29, 2012 9:18 am
So what started as a pretty straight forward job ended with mayhem & dissaster.
Don't know that outer basket comes off so easily becuz its pressed upon the primair wheel that drives the gear train.
...think its the end of my attempts...the boy/girl who locked that bolt upon the basket in the factory sure has done a great job...that bolt will never come out I guess unless you drill it out or something :(
kevxtx
Re: Slipper Clutch
Postby kevxtx » Sun Apr 29, 2012 10:58 am
Mine came straight off with my air gun. I have removed my slipper clutch twich since it was fitted & have had no problems.
Vortex155
Re: Slipper Clutch
Postby Vortex155 » Sun Apr 29, 2012 4:58 pm
yeah gonna buy one myself...that damn clutch basket has to go off and that outside basket also, so engine has to be opend.
First order a new basket and find another clutch tool this one destroys the outer basket.
Vortex155
Re: Slipper Clutch
Postby Vortex155 » Mon Apr 30, 2012 5:15 pm
Okay this may seems stupid...but to release that nut is it left or right turn...i tought it was right wire, can't see any wire outside the center bolt. The technical manual don't mention it.
Thing is I have use of an electric wrench tool and it can destroy the complete gearbox when it works in the opposite direction to release that nut, so turning tighter in stead of releasing the center nut.
Thought it would be more easy.
Marked that center bolt...didn't gave one mm after using the power tool...fact is the 32mm flew right over it.
After measuring it seemed it's USA type so you need a 30.6mm nut to release it...this ought to be written down in the manual imo.
kevxtx
Re: Slipper Clutch
Postby kevxtx » Mon Apr 30, 2012 8:51 pm
Anti clockwise to release, in your case put the bike into gear then undo the nut, make sure you use locktite on the nut when refitting.
I normally put the bike into gear, leave the clutch plates in place & press them down with my fingers with one hand & undo the nut with the other hand, with the plates still in place it stops the inner hub from kicking around when you use the impact gun.
MY STM slipper.
Return to RC8(R)
