sprocket change
kylezx10
sprocket change
Postby kylezx10 » Wed Jul 02, 2014 1:13 am
I would imagine I need the chain adjuster & what size nut holds it on. I'm a pretty descent mechanic just need a little heads up
Re: sprocket change
Postby ktmguy » Wed Jul 02, 2014 7:31 am
kylezx10 wrote:I would imagine I need the chain adjuster & what size nut holds it on. I'm a pretty descent mechanic just need a little heads up
A bit more info mate... front or rear sprocket? And yes any sprocket change needs chain adjusted.
On the 1290 piece of piss to do.
kylezx10
Re: sprocket change
Postby kylezx10 » Sun Jul 06, 2014 3:14 pm
yes 1290 front sprocket & will it void warranty. will the akro pipe void the warranty? they both state race only
Towbar
Re: sprocket change
Postby Towbar » Sun Jul 13, 2014 4:51 am
Front sprocket doesn't need the chain split... see the "other" forum...! makes the bike miles more rideable...
(dunno why we've got two forums for the same bike ?)
kylezx10
Re: sprocket change
Postby kylezx10 » Mon Jul 14, 2014 2:22 pm
got it done piece or cake remove clutch activator watch for small parts falling out {pin] LOOSE wheel, chain lock adjuste CCWr to loose chain slip chain of sprocket slip off rear sprocket put on new sprocke dont forget to bend washer adjust chain per book easiest chain a djust ever top of chain goes between 2 marks on swing arm any one can do it. ps 32 mm socket is required i just put in nutral an hit it with 18v makita impact.CAKE! pipes next in august UGH
kylezx10
Re: sprocket change
Postby kylezx10 » Mon Jul 14, 2014 2:25 pm
dealer says he wont void warranty for either sprocket or pipe even if i install my self. they are both ktm parts
Pikey
Re: sprocket change
Postby Pikey » Sat Aug 09, 2014 5:33 am
Disappointing yet again.
Loosened off my wheel the other day and adjusted it right forward to get chain off and change sprocket and as I did loads of water ran out of swing arm, not been out in rain for a while so looks like it is holding water in there somehow, not good for the bike in the long run, just going to take a while to work out how to stop it
ferret990
Re: sprocket change
Postby ferret990 » Sat Aug 09, 2014 6:07 am
I don't know about the older Superdukes, but we had to drill holes in the bottom of the SMT's swingarms to let the water out :roll:
They didn't have sexy modern SSSA's tho....
Glass half full Pikey; your rear end may be full of water, but it doesn't wobble.
Re: sprocket change
Postby ktmguy » Sat Aug 09, 2014 7:30 am
It's the new fad now, water cooling!
As ferret mentioned we will be drilling holes in the swingarm again.... :roll:
Where did the water come out, in between the hub and the swingarm?
Also wonder where it gets in??? :shock: Another mystery....
Pikey
Re: sprocket change
Postby Pikey » Sat Aug 09, 2014 11:23 am
Yeah looks like I came from between hub and swing arm, funny thing was it only came out as the wheel moved all the way forward, loosened it and moved a bit, tried to remove chain, not enough, so move it again all the way forward and all of a sudden the water runs out
