How to change the speedo correction rings.
Re: How to change the speedo correction rings.
Postby abc » Fri Sep 09, 2016 3:29 am
whufc0 wrote:its a hell lot easier to do them up then to undo them.
thats because you get stiction between the tapered faces - this is always the case when undoing anything with a mating taper.The wider the tapered surface the more stiction.
I little molly grease on both the thread (to stop binding) and a little on the taper of the nut will help everything seat down properly and also transfer the correct torque figure to the assembly without too much influence from stiction.
Postby jmann » Fri Sep 09, 2016 3:40 am
I thought Striction was when two mating surfaces stuck together... You know, like when your bellies stick together with the sweat :lol:
