LED Bulb Kit
MacaveliMC
LED Bulb Kit
Postby MacaveliMC » Thu May 19, 2016 1:54 pm
I don't think anyone else posted this, but I was perusing the Rottweiler Performance page of Super Duke 1290 parts, and noticed they finally have this little gem!!!
Cyclops Lumen LED headlight kit!!!
http://www.rottweilerperformance.com/cy ... -bulb-kit/
Hoping to get one sometime in the near future! :o
LED Bulb Kit
Postby Sarasota_Steve » Fri May 20, 2016 2:46 am
Looks very similar to the bulb I had on my other SD.
See http://www.superduke.net/forum/viewtopic.php?t=24752
08 990 SDR
08 990 SDR (For Sale)
wills
Re: LED Bulb Kit
Postby wills » Thu Jun 09, 2016 8:03 pm
Just fitted the light and boy it's bright! Took a little finagling to install, definitely keep the resistors apart.
Touring the West Coast
xtremewlr
Re: LED Bulb Kit
Postby xtremewlr » Thu Jun 09, 2016 9:04 pm
Order up the bulb directly from Cyclops yesterday.
crazyinp
Re: LED Bulb Kit
Postby crazyinp » Thu Jun 09, 2016 11:33 pm
There is a long tread on this, you can put together kit for much cheaper and don't need to use huge and hot load resistors
______
In the Garage:
2015 KTM Superduke 1290R
2013 Ducati Panigale R
aracheon
Re: LED Bulb Kit
Postby aracheon » Fri Jun 10, 2016 5:44 am
crazyinp wrote:There is a long tread on this, you can put together kit for much cheaper and don't need to use huge and hit old resistors
Link?
Crash
2014 SDR
crazyinp
Re: LED Bulb Kit
Postby crazyinp » Fri Jun 10, 2016 7:59 pm
http://www.superduke.net/forum/viewtopic.php?f=29&t=24704&hilit=LED&start=50
I did try with 3 different bulbs and 1KOhm resistor.
______
In the Garage:
Turkishexpress
Re: LED Bulb Kit
Postby Turkishexpress » Thu Jun 30, 2016 2:52 am
I actually ended up installing the Rottweiler kit that they have and it works great so far. No errors.
2015 SuperDuke 1290 R
2013 Victory Vision Tour
K7 Gixxer 600 (Track)
Joe Biker
Re: LED Bulb Kit
Postby Joe Biker » Mon Oct 03, 2016 12:25 am
just installed the cyclops bulb and WoW what a difference.
put resistors on opposite side,cut the old bulb rubber down
so that fan is exposed.
Tight fit but it works n is fooking bright plus it has both
high n low beams. 8)
MacaveliMC
Re: LED Bulb Kit
Postby MacaveliMC » Fri Apr 28, 2017 1:20 pm
For those of you who installed the Cyclops one, did you have to adjust beam height? I just installed mine, and when I called them to ask a couple questions they mentioned I'd most likely have to adjust it.
