How easy is it to change the 1290 rear brake lever?
Plake
Postby Plake » Mon Jul 11, 2016 8:57 pm
Managed to bend mine by leaning too far on a 5th gear rear wheel steered right turn*
*Drove off with the disc lock on last month
Looks like there's a circular spring attached to the heel of the lever. Is the lever something that I can easily change myself? I'm slightly better than barely mechanically competent but prone to compound disasters.
SUPERDUKEINOZ
Re: How easy is it to change the 1290 rear brake lever?
Postby SUPERDUKEINOZ » Mon Jul 11, 2016 10:05 pm
You bent the lever from it hitting the ground cornering?
Changing to another stock lever is an easy 2 min job, what lever are you using to replace it?
Plake
Postby Plake » Tue Jul 12, 2016 12:44 pm
Will be a stock lever body, just not clear how the spring attaches to it or if any other parts will be needed. And no, it wasn't cornering :lol:
xtremewlr
Postby xtremewlr » Tue Jul 12, 2016 6:01 pm
2 bolts, one to hold the lever, one attaches the brake master. Spring attachment is nothing fancy, quite simple really. Take it apart and you will see.
