Standard Grip Change
scamb66
Postby scamb66 » Fri Oct 06, 2017 7:28 am
Ok I know this is simple but I am posting this to stop guys purchasing standard grips which wont fit on the 1290 throttle tube.
The new grips are double the price of standard grips (I paid A$66) but they do come installed on the throttle tube.
As you can see from the old tube there is slots abound on it, would be a pain to install a new grip on the tube.
4 screws has the switch block apart and the tube just slides off. New one slots in in seconds. All in all its an easy 5 minute job.
lc4
Re: Standard Grip Change
Postby lc4 » Sun Oct 08, 2017 10:03 am
Nothing a grinder would not fix :D
Postby Colonel_Klinck » Sun Oct 08, 2017 11:54 am
I get why they did it, it makes heated grips easier to install on both sides but the price of the clutch side tube with grip on it is a piss take. I take it pre 2017 bikes the tube and grip come as one on the clutch side as well? Can't find a fiche for the 2017 anywhere.
Postby Aphex » Sun Oct 08, 2017 10:34 pm
Colonel_Klinck wrote:I get why they did it, it makes heated grips easier to install on both sides but the price of the clutch side tube with grip on it is a piss take. I take it pre 2017 bikes the tube and grip come as one on the clutch side as well? Can't find a fiche for the 2017 anywhere.
Everything is in USD but for information purposes you can use this site: http://oemparts.chaparral-racing.com/oemparts/l/ktm/59aa05b576a4a259183a537f/2017-1290-super-duke-r-black-parts
Postby abc » Mon Oct 09, 2017 2:30 am
A little off topic I know but If you have a lot of backlash in the drive tangs on the throttle it is a worthwhile mod to build up the tangs with epoxy. I believe the early model 1290s had more free play than necessary. Once I did this on my bike it made a huge difference and the throttle is now very precise. I ride around town in traffic in sports mode and have good throttle control and no lurching due to backlash in the mechanism.
It was one of the early changes I made to my bike and it went from a pig in traffic to something much nicer to ride.
It is a very simple mod and makes a big difference to the stock arrangement.
I don't know if the later bikes had these clearances rectified in production or not.
scamb66
Postby scamb66 » Mon Oct 09, 2017 10:31 am
abc wrote:A little off topic I know but If you have a lot of backlash in the drive tangs on the throttle it is a worthwhile mod to build up the tangs with epoxy. I believe the early model 1290s had more free play than necessary. Once I did this on my bike it made a huge difference and the throttle is now very precise. I ride around town in traffic in sports mode and have good throttle control and no lurching due to backlash in the mechanism.
Your right it probably is a little sloppier than it should be but I hadn't really thought about it until you mentioned it.
As you say, its an easy fix.
arg
Postby arg » Mon Oct 09, 2017 12:12 pm
My 2017 has too much slope, I'll give this a try. Thanks.
