Exhaust header leak
oczer79
Exhaust header leak
Postby oczer79 » Sat Apr 19, 2014 5:57 pm
I had a small mishap today where the rear header pipe under the engine hit a rock. It bent the whole header up and now it's leaking where the header attaches to the cylinder head. You can't see any leak, but i know it's there because the noise has changed and it backfires a lot when letting go of the throttle.
My question is, can I still ride the bike while waiting to get it fixed, or is there risk of valve damage?
KTM Superduke 1290 R
Re: Exhaust header leak
Postby bic_bicknell » Sat Apr 19, 2014 6:09 pm
Why not fix it immediately? All you probably need to do is undo all the connections on the exhaust and reassemble it true. Maybe you need a new gasket between the header and the cylinder head but you can check that out quickly. If you haven't had the exhausts off before or for a long time it's worth soaking the nuts and thread with a penetrating oil because they can seize on and you can snap a stud off which is a pisser. I'd advise that if you are ordering parts like gaskets then order four new copper nuts - it's worth it.
But if you have to ride it in the mean time then I think you would be OK, it just might run a bit lean.
oczer79
Postby oczer79 » Sat Apr 19, 2014 6:14 pm
I only have 250 km left before i have to take it to first service, i figured it could just wait until then. It's easter and all shops are closed so I wont be able to buy a new gasket, thats why id rather not remove the headers. Besides I can clearly see there is a dent in the pipe from the force of it being pushed up.
Postby bic_bicknell » Sat Apr 19, 2014 6:41 pm
What were you doing? Motocross? :lol:
oczer79
Postby oczer79 » Sat Apr 19, 2014 7:00 pm
I had an argument with a sidewalk. It got heated, words where said, punches where thrown. In the end we both ended up a little worse for wear. :?
BTW, the 1290 has less ground clearance then it seems.
Postby No. 47 » Sat Apr 19, 2014 8:22 pm
No risk of valve or any other damage on the 990 so would assume the same for the 1290 - have they really continued with the rear header gasket detail?
oczer79
Postby oczer79 » Sat Apr 19, 2014 9:40 pm
No. 47 wrote:No risk of valve or any other damage on the 990 so would assume the same for the 1290 - have they really continued with the rear header gasket detail?
I am unfamiliar with this issue. Are leaking headers a common occurrence?
DMacL
Postby DMacL » Sun Apr 20, 2014 8:18 am
1290 gaskets are identical to 1190 ADV ones, I didn't check any other bikes though.
Postby No. 47 » Sun Apr 20, 2014 9:34 am
Misread your post - was thinking same as 990 ceramic/graphite ring at rear of rear header.
