Fuel tank removal
MaximusVR46
Fuel tank removal
Postby MaximusVR46 » Fri Apr 25, 2014 6:10 pm
Does anyone have a guide to removing the fuel tank? When disconnecting the hose does fuel piss out everywhere?
Lets Ride!
iannowi
Re: Fuel tank removal
Postby iannowi » Fri Apr 25, 2014 6:27 pm
tiny amount of fuel will leak...less than a thimble full....just have a rag handy
Postby bic_bicknell » Fri Apr 25, 2014 7:40 pm
There is a connection on the fuel pipe that just needs disconnecting. No leak. Just unplug.
Remember, if you haven't done this before, that there is a chance that your tank will experience the distortion problem if you remove it for a long period of time and will not go back easily. Don't know why you want to remove the tank but if possible replace within a few hors and you will be OK.
Are you just lifting it or taking it off?
If for a long period I'd suggest draining the tank of fuel.
DMacL
Postby DMacL » Fri Apr 25, 2014 7:49 pm
May or may not be of comfort, but my tank had been off for about two weeks while I was fiddling with things. Sat 3/4 full of fuel.
It's refitted no problem, no signs of distortion etc.
Fingers crossed it stays that way!
For removing the tank:
Quick connect LHS can be disconnected with tank on.
Two allen head bolts under seat
Tank lifts to disconnect two connectors, a white one and a black one
Tank slides backwards out from locating thingymjigs at front.
Jim H
Postby Jim H » Sat Apr 26, 2014 12:31 am
DMacL wrote:May or may not be of comfort, but my tank had been off for about two weeks while I was fiddling with things. Sat 3/4 full of fuel.
This could be good news for the 990 crop too - class action opinion poll option 2. Is there any lateral play DMacL across the front spigots? If the tank is stable longitudinally, I would assume it remains stable transversely.
jamiehastings@btinternet.com
Long is the way and hard, that out of Hell leads up to the light.
DMacL
Postby DMacL » Sat Apr 26, 2014 6:05 am
Hard to tell Jim, the front mounting bits have a thick piece of rubber around them so it's quite a tight fit into the tank. There does seem to be some freedom for the tank to move a little though.
