Tips for changing a fork seal
bikelee
Postby bikelee » Fri Jun 09, 2017 2:05 pm
:( I have a leaking left front fork seal on my 2014 1290 SD. I've changed seals on many other bikes with Ohlins, Showa and Kayaba. Any quirks working on WP ? Thanks for any help or advice.
Re: Tips for changing a fork seal
Postby Aphex » Fri Jun 09, 2017 4:47 pm
I know my buddy at work needed special tools to work on my 990 forks.
Have you tried taking a bit of card stock and running it around the seal to see if something is just stuck in there?
bikelee
Postby bikelee » Fri Jun 09, 2017 8:24 pm
I'm gonna try that. I have a Seal Mate somewhere in the garage. I'll see if that alleviates the problem.
Postby Sarasota_Steve » Sat Jun 10, 2017 2:52 am
I heard 35mm negative film works great for that.
bikelee
Postby bikelee » Sun Jun 11, 2017 3:20 pm
:( I found my Seal Mate and have verified I DO have a leaky bad seal.
When i was pushing down and up on the forks I heard a distinct clicking noise. I thought it might be the steering bearings so I put the bike on a rear stand and lifted the bike from underneath with a jack and pulled and pushed the bottom of the fork and no play at the steering head. Any other ideas ??
Thanks !!
Postby REDTALE2000 » Mon Jun 12, 2017 1:53 am
Torque the top triple clamp nut.
They seem to work loose and the triple clamp will move just a bit on the stem and make that sound.
bikelee
Postby bikelee » Mon Jun 12, 2017 2:16 pm
REDTALE2000 wrote:Torque the top triple clamp nut.
:D Did the torque and it worked like a charm !! No more clicking. I wish the seal change would be that easy. Thanks for the great info.
Stu990
Postby Stu990 » Mon Jun 12, 2017 2:34 pm
:shock: what's that! :mrgreen:
coyo
Postby coyo » Wed Jun 14, 2017 1:33 am
If it's like the 990, I had to source out a very thin wrench in order to be able to get onto the nut with the spring compressed. Mine were too thick to fit. Other than that, pretty standard.
Users browsing this forum: Google [Bot] and 3 guests
