OIL LEAK FROM SHIFT SHAFT!!
StuartJ
Postby StuartJ » Wed Jul 26, 2017 11:37 pm
ANOTHER OIL LEAK!! :x
Discovered a slow drip coming from the shift shaft as it enters the gearbox. Only a few drops a day when on the side stand, but still fooking annoying. Has anyone else had this issue with the 2014-2016 models? I had a look at parts diagram and there doesn't seem to be an 'O' ring in the assembly that could go bad. Any ideas what it could be? Thanks
Re: OIL LEAK FROM SHIFT SHAFT!!
Postby Motogoon » Thu Jul 27, 2017 6:31 am
No surprises there, KTM's and oil leaks, they're the modern equivalent of the old Triumph's!
Sorry not much help :(
StuartJ
Postby StuartJ » Thu Jul 27, 2017 12:59 pm
https://scontent-ort2-1.xx.fbcdn.net/v/ ... e=59F5F8EE
I think the guys over on the facebook 1290 group have it figured out. Its a bad shaft seal ring, hopefully it'll be pretty straightforward to replace
Roja
Postby Roja » Sun Jul 30, 2017 6:43 pm
I just finished fixing an oil leak due to a fissure in the clutch plate.
I wish you luck at solving this cheaply and quickly!
StuartJ
Postby StuartJ » Wed Aug 02, 2017 7:32 pm
Thanks mate.
BARP
Postby BARP » Mon Aug 28, 2017 7:37 am
I had a similar, very slight slow leak, mine was from the gear selection sensor seal.
Took me a couple of weeks to find the source because if I was riding every day (or similar) there would be no sign of oil, then as it sat still for a week it would build up enough to drip a couple of drops onto the exhaust, then on start-up it would smoke and smell bad as it burnt off almost immediately. I would ride, then let it sit for a week, forget about it, start the bike and it would burn off and I couldn't find the source.
.::Scott::.
2015 KTM1290 SuperDukeR
