Greetings from Holland
introduce yourself
Bazzaz
Postby Bazzaz » Wed Apr 11, 2018 2:40 pm
Hi!
I've been a member for a while but I figure let's introduce myself and contribute (and ask) some more around here.
Name is Sebastian and I'm from the Netherlands (The Hague to be specific).
Since june last year I am in possession of a 2010 Superduke R which I already love by now :D
I rode it last year like I bought it and figured I would put some energy in it this winter so up until now I've done;
- Wrapped the exhaust
- Different steering bar (Contour Henry/Reed bend)
- Checked the valve clearance
- Replaced spark plugs
- Changed the oil/screens/filter
- Dismounted the SAS
- Removed second throttle plates/flies
- Mounted RC8 velocity stacks
- Removed the crankcase breather from the airbox to a separate filter
- Removed the stock fuel filter from the fuel pump
And currently I am in the proces of;
- Putting in a in-line fuel filter between tank and TB's
- Mounting an ITG airfilter
I got a lot of helpful info from this forum as well as the current map I'm running (akra smoothened).
The 28th it's going on the dyno to see how it runs, until then I'm looking around to find a better suitable map for my current set-up but it's not that easy.
In short; Hi, see you around! :)
Re: Greetings from Holland
Postby Scotty » Wed Apr 11, 2018 4:15 pm
Hi Sebastian, welcome aboard, that looks like a very tidy SDR you have there, nice work!
Postby Sarasota_Steve » Wed Apr 11, 2018 9:03 pm
Hi Sebastian,
Welcome in. That is the prettiest (and fastest) color IMHO.
There’s always something to do to an SDR isn’t it?
Postby DukeNukem999 » Thu Apr 12, 2018 1:13 am
Welcome and nice ride ;)
scamb66
Postby scamb66 » Thu Apr 19, 2018 12:18 am
Welcome Seb, mate I still think that model looks great. Good to see.
Bazzaz
Postby Bazzaz » Thu Apr 19, 2018 8:57 am
Thanks all!
Put it together last tuesday and finally took it for a testdrive, what a difference does that ITG filter make :D
I also had stalling problems which were due to the fuel filter (at least that was the only viable option left) so I changed the filter and added the inline filter and that problem seems solved too (although I will truly believe it after the next longer ride :P)
Return to Hello
