TuneECU: Official Topic!
Bert
Re: TuneECU: Official Topic!
Postby Bert » Wed Jan 18, 2012 10:08 pm
kowekiller wrote:[...]
I uncheck all options and then hit download. Download goes through smoothly and all options remain unchecked but I still have codes. I do not have the 02 delete kit or unpluged,just unchecked in Tuneecu. Matbe thats it. Do i need the resistors? the codes are P0022(something like that) and 2nd flies code. Ill have a look tonight and post them up. I may try plugging it into a desktop computer and see what happens.
Like I said in the previous message, there is no need to disconnect the O2 sensors. And you don't need resistors or what not connected.
Connect your bike to a PC and do a fresh read of the map ('ECU' > 'Read Map'). Verify that all items that need to be unchecked are indeed unchecked.
If they are not, uncheck them and download the map to the bike.
After that erase error codes via 'ECU' > 'Erase Error Codes'.
2006 KTM Super Duke Titanium ~ Full Titanium Akra Evo ~ MH Motobox and flies
VW TSI 1.4 problemen
Postby Colonel_Klinck » Wed Jan 18, 2012 10:15 pm
MrZ32 wrote:klink... i sent through the email.
Yeah got them and they are up m8.
Did you see my reply?
Doon
Postby Doon » Wed Jan 18, 2012 10:46 pm
When you uncheck the boxes I thought you had to do a save as first ,then sent to the ecu.
Thats what I have been doing.
2007 SDR, GSXR 1000 Scorpion Pipe, ITG foam filter,Rc8 stacks, PCV with autotune,basic breather mod, dual seat conversion.
kowekiller
Postby kowekiller » Thu Jan 19, 2012 1:54 am
Good question. Wifes almost home so I can go fiddle with the bike.
If it has tits or wheels I'll ride it!
2008 SDR
SoCal
MrZ32
Postby MrZ32 » Thu Jan 19, 2012 2:24 am
Yes.. Thanks mate.
All, these are maps that will run fairly smoothely without you having to worry about a custom map that could be too lean for your bike. The akra map is plenty rich enough for just about any mod you can throw at your bike (bolt on). Those who think that the akra isn't rich enough.. Go replace your graphite seal and then re test for a TRUE result
Eyeflow
Postby Eyeflow » Thu Jan 19, 2012 11:01 am
jambox
Postby jambox » Thu Jan 19, 2012 5:51 pm
Eyeflow wrote:any one tried this cable w/ positive results?
http://www.dualsportwarehouse.com/CJ-Designs-Tune-Ecu-Cables-For-KTM-Engines-TUNE-C-KTM.htm
/Mats
Think they are the ones that Powercell had something to do with. If they are, then a lot of people have had good results from them.
kowekiller
Postby kowekiller » Thu Jan 19, 2012 8:09 pm
Alright. Got the bike loaded up againlast night and cleared all codes using the upper tool bar.
2008 SDR
SoCal
omky756
Postby omky756 » Thu Jan 19, 2012 8:20 pm
kowekiller wrote:Alright. Got the bike loaded up againlast night and cleared all codes using the upper tool bar.
Killer..!!
8)
kowekiller
Postby kowekiller » Thu Jan 19, 2012 11:28 pm
Killer..!!
8)
I do believe I owe you a thanks Sir!
2008 SDR
SoCal
fusca95
Newbie
Postby fusca95 » Sun Jan 22, 2012 10:43 pm
Gentlemen, this is my first post.
I live in Brazil and I have one of the few SuperDuke 990 10-10 of this country.
I found the forum a little time here and met tuneECO. My bike has a yield far below expectations, barely walking with a honda hornet 600cc. I read the ECU and I realised that my map is the same as Europe.
I have some doubts and I hope you can help me: The connection to the engine always falls on, what do I do? Is there a map for setting the A / F? In Brazil we have the E22 as fuel standard.
Thank you all.
Postby ktmguy » Thu Jan 26, 2012 10:52 am
fusca95 wrote:Gentlemen, this is my first post.
Thank you all.
I had the same problem of disconnecting as soon as I started the engine. Soldering the shield on the negative pin of the USB ODB connector and fitting a ferrite choke fixed the problem.
I should do a how to of this one of these days.....
K-Mac
Postby K-Mac » Thu Jan 26, 2012 11:38 am
Thank you all.
Yes, please do it....like now. :-)
2018 KTM 1290 Super Duke R
2016 KTM 690 Duke R
2014 Aprilia Tuono V4R APRC ABS
Bert
Postby Bert » Thu Jan 26, 2012 2:52 pm
K-Mac wrote:
ktmguy wrote:[...]
Look here (scroll down to 'UPDATE'). The site also has a picture:
So, solder a wire to the outer shielding of the USB cable and connect it to the pin of the plug shown in the picture.
Ferrite thingies can be bought in an electronics store and snap over the cable.
omky756
Postby omky756 » Thu Jan 26, 2012 7:06 pm
Bert wrote:
K-Mac wrote:
ktmguy wrote:[...]
THANKS BERT..!!
8)
Vortex155
Postby Vortex155 » Fri Jan 27, 2012 6:50 pm
Never had any problems with my tune ecu cable I solderd out of an old usb cable, that cable is completely isolated with alu shield.
My cable is rather large bout 2m, so I can take my notebook upon a table to do some adjustments @ my RC8.
Think the most problems arrive with cheap FDTI chipsets inside the usb connector.
Have bought another obd2/usb cable form another supplier, this is for a TuneECU cable I'm gonna make for a Dutch guy from RC8 forum, shall see if it works out with that connector and with the ready made female obd2 with ain't shielded.
I now have the advantage that I have 2 obd2/usb connectors and 2 obd2/B6PA connectors, so troubleshooting will be easy.
Vortex155 on twitter
omky756
Postby omky756 » Fri Jan 27, 2012 7:19 pm
It's interesting..Not being a techy...I don't quite see why...
but with the same computer and cable..
Cable has the shielding and USB grounding done too..
One '08 SD and one '08 SDR...
Connects perfectly without freezing up or dissconnecting on the SD...
However...
Different story for the SDR...
SDR is more tempermental...anyone with ideas or run accross this..??
8)
K-Mac
Postby K-Mac » Sat Jan 28, 2012 1:02 pm
Bert wrote:
K-Mac wrote:
ktmguy wrote:[...]
Thanks Bart. The inside of my cable looks different.
2016 KTM 690 Duke R
Tom-Hamburg
Postby Tom-Hamburg » Sat Jan 28, 2012 6:06 pm
Remember, the Aprilia OBDII-Pin5 used for grounding, but KTM's OBDII-Pin4 uses for grounding.
The picture from Moto Abruzzo is for Aprilia
BR, Tom
Triumph Speed Triple 1050
Triumph Rocket Roadster
Postby ktmguy » Sun Jan 29, 2012 6:50 am
To avoid disconnection issues check and fix the following:
Make sure the shield of the USB cable is fixed to the negative of the cable. See the wire and shield together in the heat shrink in the following picture.
I de-soldered the cable, stripped it back a bit, joined the shield and the negative and soldered it all back on with some heatshrink around it.
I also fitted a ferrite choke on the cable as you see here:
On my bike Tuneecu disconnected as soon as I started the engine, these 2 mods fixed the issue and now it stays on no problem.
iannowi
Postby iannowi » Sun Jan 29, 2012 11:09 am
hi guys, I recently bought a 2007 SDR..lots more fun to ride than my last bike [2007 Z1000]...the thing is, the more I read about this tune ecu business the more I get the urge to go ahead and do it....not necessarily to get more bhp but for a smoother, less snatchy ride. Also thinking MH box, sas removal, 02 off. Can someone please advise me of how I should get started[ecu cable and sas plates on order].how difficult a process is it for a novice.. I have also tried to open up the .hex maps on the very fist page of this thread, but cant seem to get them open...is there a way around this problem...any advise would be appreciated..thanx Ian
jambox
Postby jambox » Sun Jan 29, 2012 2:16 pm
iannowi wrote:hi guys, I recently bought a 2007 SDR..lots more fun to ride than my last bike [2007 Z1000]...the thing is, the more I read about this tune ecu business the more I get the urge to go ahead and do it....not necessarily to get more bhp but for a smoother, less snatchy ride. Also thinking MH box, sas removal, 02 off. Can someone please advise me of how I should get started[ecu cable and sas plates on order].how difficult a process is it for a novice.. I have also tried to open up the .hex maps on the very fist page of this thread, but cant seem to get them open...is there a way around this problem...any advise would be appreciated..thanx Ian
To open up the .hex maps, you need to download/install the TuneECU program from the website, then open the .hex from "File, Open" (after downloading the map of course) on the main TE screen.
It's easy to use once you've had a play with it
iannowi
Postby iannowi » Sun Jan 29, 2012 3:45 pm
Many thanks jambox....it makes a bit more sense now...now for my next question....with there being so many different maps to choose from, any ideas for a 2007 sdr..slip on HPCorse exhaust....I want to remove sas and eliminate the o2 sensors....not yet bought the MH box, but the bike has a BMC air filter....any ideas which would suit...thanx
jambox
Postby jambox » Sun Jan 29, 2012 4:05 pm
Seeing as not much has been done to it I'd recommend:
07+ EU SD Akra Smoothened
https://files.me.com/craig.wiltshire/lh0tru
07+ US SD Akra Smoothened
https://files.me.com/craig.wiltshire/pk22jr
Depending where you are. :wink:
If using one of the above, the O2 sensors have already been turned off in TE, so no need to fit eliminators. As for the SAS, if it hasn't been removed/blocked yet, leave it turned on in TE as it will cause popping/banging as I found out.
For other maps, there are loads here viewtopic.php?f=18&t=14763
emuexport
Postby emuexport » Mon Jan 30, 2012 2:20 pm
Whats a good map for 09 SD with akros, no baffs, motobox & no 2nd flies?
2009 SuperDuke with Akrapovic Pipes, MotoBox, PCIII, SAS removed, O2 sensors removed, Scottoiler, Motoflies, Moto Clutch cover, moto heel guards, Rizoma levers. Seat cover from biketec.de Shoed with: Pirelli SuperCorsas
Users browsing this forum: Google [Bot] and 3 guests
