chip wrote:Turned the idle screw 360 clockwise and heard a marginal increase in idle revs. Also when ignition turned on the startup noises are back to normal ie they eventually stop where before it sounded like some electric motor just kept going.
Off to the mechanic for new tyres so will see if I can get the tps readings. Also found an electronics guru in town so might see if I can get him to look at the black boxes on the throttle bodies.
Thom wrote:the surging is now near constant. Started the bike this morning, went to drive off, shifted into second. By the time I made it to the stop sign, it was surging to 3000. Stopped bike, shut it off, restarted and drove off. Same thing, within 2 gear changes, it was surging again.
I actually watched it at a stop light, start at idle, around 1450, and move to around 3800 RPM.
TPS, at rest is .64V, but I don't know what it is at WOT. I'll take a look at the stepper arms but is there anything else I should check? All plugs just got a healthy dose of dielectric grease (thank you amazon).
No. 47 wrote:Forgot to reiterate checking TB rubbers also.
No. 47 wrote:No idea re test for cable test other than borrowing someone else's and see if that works - if TB rubbers now good and TPS setting proves to be OK, suggest starting with the fabled BGC routine and checking clutch switch.
Users browsing this forum: No registered users and 7 guests
