Headlight fuse blowing... HID
Reaper
Postby Reaper » Wed Jun 01, 2016 11:27 pm
Been trying to fit a projector headlight with HID conversion to my SD 990.
I have tried changing from H3/H7 to H4 as i only want 1 projector.
I thought the headlight itself was the problem but that isn't the case as if i turn the bike on without the light connected at all, just the headlight wire the fuse still blows. If I connect up the original wire along with the original headlight all works fine.
So i have come to the conclusion it has something to do with the second wire i got.
It was one for the H3/H7 that I cut off the ends and wired up to a H4 connector.
I have tested the wire and there appears to be no short circuit.
Does anyone have any suggestions as to what could be the issue?
