990 power parts top yoke doesn't fit
dipper
Postby dipper » Fri Jun 30, 2017 1:11 pm
I have a 2006 SD with cnc'd KTM top yoke that I'd like to fit to my 2008 SD. It lined up fine and fitted no problem. However, when trying to fit the stock 2008 yoke to the 2006 it doesn't line up! I've even tried dropping the wheel and forks off, fitting the yoke then sliding the forks in just in case there was some alignment issue with the load being on the wheel. Still no joy
If the offsets are different between 2006 and 2008 surely they wouldn't be compatible in either direction?
