Oil change?
Droldaerd
Oil change?
Postby Droldaerd » Tue Jul 25, 2017 10:19 pm
I'm about to do an oil change and was wondering if the item, http://www.bikebandit.com/aftermarket-p ... r?m=140542 , comes complete with the extra filter screens or do I need to purchase them separately?
Re: Oil change?
Postby Aphex » Tue Jul 25, 2017 10:30 pm
That's just a filter.
If you want a full KTM brand oil change kit then you would need this: https://ktmtwins.com/products/ktm-950-990-lc8-seal-and-oil-filter-kit
However I just clean all my screens​ instead of replacing them been fine for almost 40k miles now.
Re: Oil change?
Postby Motogoon » Tue Jul 25, 2017 10:49 pm
Me too, those things never seem to wear out. Unless they're damaged don't bother.
Droldaerd
Re: Oil change?
Postby Droldaerd » Wed Jul 26, 2017 4:41 am
Thanks all! Anyone point me to the direction of the screens I should clean?
crazyinp
Re: Oil change?
Postby crazyinp » Wed Jul 26, 2017 6:10 am
Like everyone else said, you don't need new oil screens, however just make sure you buy new o-rings. The OEM filter doesn't come with one and if you remove and clean your oil screens, I would recommend to replace the o-rings
07700390261 - 1x (Oil Filter O-ring)
0770170200 - 4x ( Oil Screen O-rings 2x per)
______
In the Garage:
2015 KTM Superduke 1290R
2013 Ducati Panigale R
Re: Oil change?
Postby Aphex » Wed Jul 26, 2017 2:12 pm
Droldaerd wrote:Thanks all! Anyone point me to the direction of the screens I should clean?
There is a thimble screen in your oil tank on the left hand side of the bike. It makes a huge mess so what I do is remove the chin fairing and cover the battery box/electronics with a plastic bags.
The other screen is on the right side of the bike below the clutch cover, you have to remove a small plate then pull it out with some needle nose pliers.
I just blow any debris out with a can of compressed air, check for tears in the screen and drop em back in.
Droldaerd
Re: Oil change?
Postby Droldaerd » Sun Jul 30, 2017 5:01 am
Thanks, ill get right on it. I ended up with just a filter. I ordered a filter kit now but will have to make this due till then.
Droldaerd
Re: Oil change?
Postby Droldaerd » Sat Aug 05, 2017 7:35 pm
I'm having troubles locating the "thimble" screen on the left side of the bike. Do I need to remove the chin fairing to see it?
Droldaerd
Re: Oil change?
Postby Droldaerd » Sat Aug 05, 2017 7:41 pm
Nm. I'm thinking its within the tube area under the oil tank?
Re: Oil change?
Postby Aphex » Sat Aug 05, 2017 7:56 pm
Droldaerd wrote:Nm. I'm thinking its within the tube area under the oil tank?
Correct it's where the hose runs into the oil tank on the bottom left near the drain plug.
Droldaerd
Re: Oil change?
Postby Droldaerd » Mon Aug 07, 2017 7:41 pm
All done. Thanks
