Oil leak still?!
Droldaerd
Oil leak still?!
Postby Droldaerd » Sun Aug 20, 2017 1:05 am
I can't seem to locate the oil leak I'm having on the alternator side of the cover. I replaced balancer shaft seal. Replaced crank breather clamps, tightened them and tightened correspond nuts and such. Included album from its area. Thanks.
Oil leak https://imgur.com/gallery/5QaPt
Re: Oil leak still?!
Postby Aphex » Sun Aug 20, 2017 2:32 am
After you replaced the balance shaft seal did you pull the airbox and clean all the oil out of it as well as clean your air filter?
Droldaerd
Postby Droldaerd » Sun Aug 20, 2017 2:41 am
No air box. Rottweiler intake.
Droldaerd
Postby Droldaerd » Sun Aug 20, 2017 2:48 am
To add. I did take everything off down to the throttle bodies and cleaned it allm
Postby No. 47 » Sun Aug 20, 2017 9:28 am
Is one way valve installed right way round?
Droldaerd
Postby Droldaerd » Sun Aug 20, 2017 11:24 am
No. 47 wrote:Is one way valve installed right way round?
For the crank case breather? Double checked. Was good. Oil doesn't be seem to be coming from intake. Something between the throttle bodies and alternator cover
Oil leak still?!
Postby Sarasota_Steve » Sun Aug 20, 2017 11:25 am
I replaced the one way valve last night and I'm reassembling this morning. I purchased the Oetiker clamping tool for the stepless stainless steel clamps to do the job properly. I'm loving the stepless ear clamps. I want to buy a whole kit sizing between 1/4" and 1 1/8".
08 990 SDR (For Sale)
Postby No. 47 » Sun Aug 20, 2017 1:22 pm
Any oil on front cam cover?
Edorta
Postby Edorta » Sun Aug 20, 2017 1:59 pm
Hi!
I still having a oil leak too mate, losing all the patience with the bike :evil:
First of all try to be sure where the oil comes.
I changed the shaft seal last summer but yesterday I took off the rubber tube of the ignition cover and it's spiting a lot of oil.
In my case i'm sure that the seal is broken.... AGAIN :evil:
If you check the tube and is dry the problem comes from the ignition or cam cover seal. Check them all.
Some bolts have cu-seal rings, did you put them?
Good luck mate!
Ride it like you stole it!!!
Droldaerd
Postby Droldaerd » Sun Aug 20, 2017 4:59 pm
No. 47 wrote:Any oil on front cam cover?
Front side is ultra dry.
Droldaerd
Postby Droldaerd » Sun Aug 20, 2017 5:03 pm
Edorta wrote:Hi!
Good luck mate!
Any bolt or nut that has the copper rings, I replaced. Replaced alternator gasket. After cleaning, I have oil on the cover from the top, dripping to the bottom. No much like 100-200 mL per a week/800 miles.
Postby No. 47 » Sun Aug 20, 2017 5:23 pm
Oil sight level tube?
Droldaerd
Postby Droldaerd » Sun Aug 20, 2017 5:49 pm
No. 47 wrote:Oil sight level tube?
Checked to be sure, but its good. No oil on the left side of the stator cover even. Originating near top of cover, possibly higher with a drip down, and drips down the right side of the stator cover. Throttle bodies and higher are dry. Between that, its hard to make out with the other hoses and engine mount bracket in the way.
Postby No. 47 » Sun Aug 20, 2017 6:50 pm
Oil pressure switch to lh rear of front cylinder?
Droldaerd
Postby Droldaerd » Sun Aug 20, 2017 10:30 pm
No. 47 wrote:Oil pressure switch to lh rear of front cylinder?
Think I found it. Little circular switch with flat square metal tab a wire up hooks on to? Mine is currently disconnected. Should I hook it back up? Also its a little too far forward to get oil where its spilling now. That side of the stator cover is fully dry. Man I'm going crazy on this!
Postby No. 47 » Mon Aug 21, 2017 8:28 am
Aye, reconnect oil pressure sensor switch - starter motor o-ring?
Droldaerd
Postby Droldaerd » Mon Aug 21, 2017 8:35 am
No. 47 wrote:Aye, reconnect oil pressure sensor switch - starter motor o-ring?
Was gonna ask that next. Cause I don't see what else lol. Gonna order one now just because.
Droldaerd
Postby Droldaerd » Tue Aug 22, 2017 7:21 pm
Do I need to remove anything within the stator cover to remove the starter.
Droldaerd
Postby Droldaerd » Thu Sep 07, 2017 4:55 pm
Starter o ring replaced... Still go oil on the cover....
Droldaerd
Postby Droldaerd » Sat Sep 09, 2017 7:04 pm
Could I have put the o ring on improperly? Should I reseat the stator gasket?
Postby No. 47 » Sat Sep 09, 2017 7:53 pm
Can only suggest cleaning all oil off, dusting with talcum powder or similar and running engine until you spot the source - could be, though, that leak is elsewhere and bring windblown onto casings when riding.
Droldaerd
Postby Droldaerd » Tue Sep 12, 2017 8:32 am
No. 47 wrote:Can only suggest cleaning all oil off, dusting with talcum powder or similar and running engine until you spot the source - could be, though, that leak is elsewhere and bring windblown onto casings when riding.
Nothing else seems to get a drop! Every engine piece, air filter all that is bone dry to the touch! Just the right half stator cover get oil on it, top to bottom. Starter seems to be dry. I figured I'd get some there by now if that seal was the problem. Maybe I have a bad stator gasket? I had put a new one on just a few months ago. Maybe I failed its placement? I also noticed that the stator cover and engine don't quite line up exactly at the seems. Is it possible my cover is faulty? I know the original owner had claimed to change one od the sides. Can't rmember which one.
Postby No. 47 » Tue Sep 12, 2017 9:18 am
Suggest remove cover and, using parts fiche, check that all crankcase dowels are in place, that all copper washers are where they should be and that all bolt lengths are correct for position - check gasket seal faces of crankcase and cover (could be that PO levered off cover and damaged faces) and replace gasket and use (sparingly) good liquid gasket to both sealing faces as well.
Droldaerd
Postby Droldaerd » Tue Sep 12, 2017 5:13 pm
No. 47 wrote:Suggest remove cover and, using parts fiche, check that all crankcase dowels are in place, that all copper washers are where they should be and that all bolt lengths are correct for position - check gasket seal faces of crankcase and cover (could be that PO levered off cover and damaged faces) and replace gasket and use (sparingly) good liquid gasket to both sealing faces as well.
Okey. Thanks. I'm gonna order a new one today and try all that when it comes in
Droldaerd
Postby Droldaerd » Tue Sep 12, 2017 6:43 pm
Is there suppose to be a copper washer for every bolt? Only see 2 on fiche
