Check your nuts! Reminder.
battleshaft
Postby battleshaft » Thu Sep 07, 2017 7:05 pm
Hello All,
Most of you will already be aware of this as a common occurrence but I thought I'd share.
These are the two most serious of the fixings that I have found to be loose (upon first check):
Front Sprocket Nut. Saved by lock washer!
Rear Sprocket bolts - 4 out of 5 were loose, 2 of which were finger tight only!
I checked my rear sprocket while I had the rear wheel out for a pre track-day tyre change.
Just thought I'd reiterate in case anyone was in two minds about checking. CHECK THEM! If they're loose, clean adequately, apply Loctite 243 and torque them to spec.
:D
battleshaft
Re: Check your nuts! Reminder.
Postby battleshaft » Thu Sep 07, 2017 7:07 pm
FYI - Bike is a 2011 SuperDuke 990
Postby Sarasota_Steve » Thu Sep 07, 2017 7:13 pm
Good advice. What are the torque specs for those bolts?
Postby Willh » Fri Sep 08, 2017 12:57 am
Check'em or else Image
Sent from my iPad using Tapatalk
DaveNZ
Postby DaveNZ » Fri Sep 08, 2017 4:33 am
Sarasota_Steve wrote:Good advice. What are the torque specs for those bolts?
The manual has torque settings Steve, well the manuals for the 1290s dose. On my 1290R (2014) on my first rear tyre change, i brought a 60mm socket, put it on my impact driver, braced myself, but it flew un done at a great rate on knots, no load on that sucker bro. Clips held it. My 1290GT was a different story, my cheep impact driver wouldn't budge it. so 2 meter pipe on my breaker bar, wife on the bike, with her foot heavily on the foot brake, and in first gear, annnnnnnnd of she came. (thank fuk).
battleshaft
Postby battleshaft » Fri Sep 08, 2017 1:15 pm
Rear sprocket bolts: Loctite 243 + 50 Nm
Front sprocket nut: Loctite 243 + 100 Nm (Sourced this through SD.net as wasn't in manual)
Note: Do not torque the front sprocket nut with the bike in gear as you may damage the gearbox. Get a friend to sit on the bike while you torque it or sit and torque yourself.
Postby No. 47 » Fri Sep 08, 2017 2:52 pm
Pages 11-22 and 11-23 of rebuild manual.
Black Out
Postby Black Out » Mon Jun 11, 2018 4:05 pm
I've had 2 of the rear sprocket bolts come loose scraping the ever loving shit out of the inside of my swingarm.
I checked the countershaft sprocket nut, also loose. This is a common problem on the Speed Triple as well.
Ducati Monster 800
Triumph Speed Triple 1050
KTM SuperDuke 990
