TuneECU engine troubles
dudelord
Postby dudelord » Sun Oct 08, 2017 8:56 pm
Hi all,
I'm a new 990 Super Duke R (2007, stock except Ixil Xtrem exhausts without DB killers) owner and loving the bike. The first thing I tried to do was to make the bike more smooth, so I ordered a TuneECU cable and loaded all the available maps for Super Duke R from the official website. All the maps give me the same problem: the bike runs like absolute horse dung. The most annoying thing is that everytime I release the throttle you can feel the RPM's going back really fast, to around 1000 - 800, and the engine becomes very "silent" as if it's not even running. Then 9/10 times the engine stalls after which I have to start it again while still rolling. Also a lot of backfire in the pipes, even in sixth gear riding around 120 km/h. (way too rich fuelling?). Weird thing is that even the standard exhaust map gives these exact problems.
This is the procedure I go through after each map download:
- Download unmodified map to ECU
- Reset adoption
- Idle speed control test
- Ride around for at least 10 minutes
- Tried the 15 min idling but made no difference at all
Now I'm not sure if I should have backed up the original map :cry: .. and there doesn't seem to be a "reset" functionality from the Windows TuneECU software so I hope I am not screwed now since my knowledge of tuning with TuneECU is almost zero. Wouldn't mind fiddling around but I also use the bike for commuting so it would be nice to have a decent running bike soon again.
Any help would be greatly appreciated!
Re: TuneECU engine troubles
Postby No. 47 » Sun Oct 08, 2017 9:16 pm
Nope - download map, reset adaption, 15 min idle without touching throttle and only then ride - even then, both my SDRs take a little while of use before settling down, eg stable tickover.
Also, check your TPS voltage using TuneECU with 0.56-0.64V range given in KTM rebuild maual.
Not sure re best map for OE airbox but aftermarket pipes but suggest KTM Akra would be best suited - there are more here viewtopic.php?f=18&t=14763 though.
Postby DukeNukem999 » Mon Oct 09, 2017 5:42 am
No.47 is right. Reset adaption is a PITA but necessary.
It took me 3 maps and the "reset process" to get it right after I got some Akra's. I had to take it out for a 30 min ride (idle revs back down to normal and much smoother).
AGRO!
Postby AGRO! » Mon Oct 09, 2017 7:48 am
You should have made a back up of your old map but why your bike is probably backfiring is because the original map would have had the sas turned off.
So go into tune ecu with the map your running and see if the sas has been turned off or not once you have turned it off do the 15min reset again and see if this fixes the problem.
To turn it off you have to right click on the sas box then untick the box.
dirty irving
Postby dirty irving » Mon Oct 09, 2017 9:02 am
A lot of backfire could be the carbon gasket gone in the riser from your headers to the mid-pipe ?
AGRO!
Postby AGRO! » Tue Oct 10, 2017 7:14 am
dirty irving wrote:A lot of backfire could be the carbon gasket gone in the riser from your headers to the mid-pipe ?
+1 It could have something to do with it also.
dudelord
Postby dudelord » Tue Oct 10, 2017 8:47 am
Cheers guys. Will try it out this weekend, and I believe the TPS voltage was above 0.7 so will have to check that out too.
And I actually really enjoy the backfire bangs, so that's not a problem.
dudelord
Postby dudelord » Sun Oct 15, 2017 6:28 pm
I have loaded the Akra Smoothened map from the link No. 47 gave, and then did the reset adoption and then did the 15 min idle. While idling the engine went up and down from 1k to 2k rpm all the time and the engine was killed about 20 times when it came under the 1k rpm everytime.
Now this map and reset made the original problem a bit better, but it still remains that while riding the rpm goes low and then kills the engine. For example while approaching a traffic light, or standing still. Idling still goes bananas with the fluctuations in the lower rpm range. I tried riding for about 30 mins but the problem remains.
TPS voltage is 0.61V.
What is the next thing I can try to smoothen her out? It's all good to me as long as the frustrating stalling ends :evil:
Postby No. 47 » Sun Oct 15, 2017 7:02 pm
Check clutch switch
Postby nampus » Mon Oct 16, 2017 12:01 pm
I've sent you a pm about a week ago, have you read that?
dudelord
Postby dudelord » Thu Oct 19, 2017 1:23 pm
Still not resolved, sadly.
Does anybody have the original mapping of a 2007 Super Duke R from Europe?
Postby No. 47 » Thu Oct 19, 2017 4:26 pm
Afaik, 2007 R map is same as standard SD map for that year - http://www.tuneecu.com/KTM_Tune_list.html
Postby Motogoon » Thu Oct 19, 2017 8:15 pm
I'm not saying it's this or trying to freak you out but your story sounds eerily similar to what the previous owner of the SD I'm dismantling told me.
He said they they tried every map under the sun + all the other usual suspects and just could not get it to run right. Eventually a part of the valve in the front cylinder broke off and the "mechanic" that stripped it down believes it was due to overheating from a lean condition due to a fuel injector not working.
Now I don't know if he's right or not but there was an exposed wire along with what looked like water damage to the plug for that injector. And I can tell you that the head and spark plug definitely looked like they had gotten very dry and hot!
I don't know how you would test for that apart from maybe pulling the plugs and seeing if they look different like one is running lean?
dudelord
Postby dudelord » Fri Oct 20, 2017 7:31 am
No.47, cheers but you can't load a SD map on a SDR. Gives an incompability error.
Motogoon, it's running more lean for sure now and that is a kind of spooky story. The thing is it actually runs better and pretty damn smooth with an Akra map. The only problem is the freaking stalling at low RPMs.
Postby No. 47 » Fri Oct 20, 2017 8:41 am
Are you sure that it's not just a faulty clutch switch?
dudelord
Postby dudelord » Sat Oct 21, 2017 9:12 am
Just noticed that the clutch switch is only pressed in about 50-60% when fully the clutch handle is fully pressed. This could be part of the problem, but it wouldn't explain why it stalls in neutral. Will update after I found a way to let it press 100%.
Dirtydutch
Postby Dirtydutch » Mon Oct 23, 2017 4:57 pm
Just bend the metal feeler.
dudelord
Postby dudelord » Thu Apr 26, 2018 2:09 pm
If anybody stumbled upon this post: I fixed it by taking it to a KTM shop and sadly they couldn't tell me what the problem was but it took the mechanic over 2 hours to get it fixed. Not really a satisfying ending, but still.
Postby Aphex » Thu Apr 26, 2018 2:22 pm
dudelord wrote:If anybody stumbled upon this post: I fixed it by taking it to a KTM shop and sadly they couldn't tell me what the problem was but it took the mechanic over 2 hours to get it fixed. Not really a satisfying ending, but still.
Couldn't tell you because it was a secret or couldn't tell you because they did a lot of work to it and don't know what actually fixed it?
dudelord
Postby dudelord » Thu Apr 26, 2018 2:26 pm
The mechanic was not there the day I came to pick it up. The owner of the shop said he had a pretty though time fixing it though, I think maybe because it's a not-so-common year / type: 2007 from Austria.
