Bike running rough
TimR
Bike running rough
Postby TimR » Mon Apr 16, 2018 5:05 pm
I just bit the bullet and got my 990 serviced, including valve check. The bike seemed fine afterwards and at the weekend I headed into North Wales for a ride.
Prior to this (2 months ago), I’d had problems with reg/rec which were resolved by fitting a MOSFET unit, but I don’t think this problem is electrics-related.
After about 100 miles (and probably 200 in total since the service) the bike started to behave strangely. I noticed revs were high and hunting in neutral at a standstill – up to about 1800 rpm. Then at around 3000rpm in the first few gears, on a neutral/light throttle the bike started to hesitate and run rough. This then spread up to about 5000rpm. The next time I stopped, the revs rose in neutral to 3000rpm. I got home OK, the bike didn’t stall and when turned off, it restarted without any trouble. There are no warning lights showing.
Yesterday I took the tank off to check there were no trapped pipes or cables – all seemed OK, the MH airbox was properly seated/secured and the rubber boots looked OK. Of course, when I put it back together and took it for a quick test ride, it didn’t show the problems. I guess it needs to be ridden for a longer time/distance to show the problem again.
I phoned the bike place that serviced it and they’ve said to bring it back in to have a look, which I am planning to do later this week. The mechanic said he thought it sounded throttle body related.
I have searched but can’t find anything to point me in a particular direction. Anyone experienced these symptoms?
Re: Bike running rough
Postby No. 47 » Mon Apr 16, 2018 6:06 pm
Could be many things but in absence of error codes, first check TB rubbers again viewtopic.php?f=5&t=12511&p=335070&hilit=Rubbers#p335070
Bazzaz
Postby Bazzaz » Tue Apr 17, 2018 10:04 pm
The hesitating and the rising idle (to 3ktpm) i've had as well, on my bike it was the TPS... mine was broken so I replaced it and set it to the correct values and the problem was solved.
TimR
Postby TimR » Wed Apr 18, 2018 9:18 am
Thanks for the replies.
I'm taking it over to the bike shop tomorrow - hopefully they will find the problem and fix - even better if they acknowledge that it was something that was set correctly during the service - unlikely I know, but I can dream!
