OE Steering Damper
OE Steering Damper
Postby No. 47 » Tue Apr 24, 2018 2:20 pm
Here's a new one, at least for me - steering damper clamp pivot bolt has rusted through and snapped (so much for spacer bush o-ring seal......), allowing damper to drop and rod to 'drill' holes through radiator - once repaired/replaced, will add a couple of loose-ish cable ties around damper and lower triple clamp to stop it dropping off below pivot bolt.
Re: OE Steering Damper
Postby jmann » Wed Apr 25, 2018 1:18 pm
Comrade 47: That sort of rust could only happen in the UK :wink: Here the bikes fall apart because of the UV 8)
Postby No. 47 » Wed Apr 25, 2018 4:41 pm
Aye but probably still worth checking wherever you may be - assembly should have been packed with grease at factory but mine was as dry and full of powder as and like a cremation urn............
Mr_Trecolareco
Postby Mr_Trecolareco » Thu Apr 26, 2018 10:27 am
Nice heads up...preventive maintenance is key over the years.
My scotts steering damper is less exposed another reason to choose it 8)
