by SDNerd » Mon Dec 10, 2018 11:38 pm
I saw this bike for sale (Craigs, Trader, etc.) ... Was listed for some time. Your current problem could be any number of things; Starting with the "easy" - Is the fuel pump coming on? If so - good - and this may seem a dumbass question - did you drain the tank and put some fresh fuel in it?
There's also a quick disconnect in the high pressure line from the tank - it's junk quality plastic (even though a CPC, er Colder Products item), and has been known to break with little provocation. Is it disconnected or broken?
Then, are you seeing spark? I'm assuming you know how to verify if you have spark, or you wouldn't have purchased a crashed bike.
I gotta ask - why not just use a factory ignition switch - might save you some headaches.
