'08 SDR
'08 SDR
Postby No. 47 » Tue Oct 25, 2016 4:27 pm
Post - AllYearBiker ACF treatment.
Re: '08 SDR
Postby Sarasota_Steve » Tue Oct 25, 2016 7:36 pm
So, this is the 3rd '08 SDR in your garage?
Congratulations!
Re: '08 SDR
Postby No. 47 » Tue Oct 25, 2016 7:54 pm
Second only.........and another half in engine, forks, rear shock, swingarm, oil tank, radiator, fuel tank, seat unit, rearsets, bars, levers, etc and more odds and sods than I would want to admit to - part of the reason why I went for another 990R rather than 1290R for the moment.
pwnd
Re: '08 SDR
Postby pwnd » Wed Oct 26, 2016 9:11 am
why the hell not. order another licence plate for it and ride them both on the same rego :P
Re: '08 SDR
Postby DukeNukem999 » Thu Oct 27, 2016 1:23 am
Congrats.. looks nice....I hope it proves to be hassle free :)
chr1s
Re: '08 SDR
Postby chr1s » Thu Jan 19, 2017 9:32 pm
Looks great!
My 990 is still going well. Thanks again for your help!
Sent from my SM-J500F using Tapatalk
speedfiend41
Re: '08 SDR
Postby speedfiend41 » Thu Jan 19, 2017 9:36 pm
Very nice! All black looks mean.
Got any spare exhausts you want to get rid of??
Re: '08 SDR
Postby No. 47 » Thu Jan 19, 2017 10:30 pm
Only OE...........
speedfiend41
Re: '08 SDR
Postby speedfiend41 » Fri Jan 20, 2017 1:28 am
No. 47 wrote:Only OE...........
Yeah, got those!
I cannot believe how bloody expensive exhausts for 990's got in a short couple of years. Jesus. $2000 plus for Akras. That's just ridiculous.
Re: '08 SDR
Postby No. 47 » Thu Feb 02, 2017 7:47 pm
Side of road in middle of nowhere with flat battery again..........
Re: '08 SDR
Postby Sarasota_Steve » Thu Feb 02, 2017 8:04 pm
Crap, that sucks.
Its those British winters killing batteries through the whole Kingdom.
Re: '08 SDR
Postby No. 47 » Thu Feb 02, 2017 8:13 pm
Replaced battery only ten days ago - fiver says it's the brown connector.
Re: '08 SDR
Postby No. 47 » Thu Feb 02, 2017 9:14 pm
Scrub that, it'll be the reg/rec that I should have replaced at same time as battery.
CEREC1
Re: '08 SDR
Postby CEREC1 » Thu Feb 02, 2017 11:04 pm
No. 47 wrote:Scrub that, it'll be the reg/rec that I should have replaced at same time as battery.
Read these fail quite often. Easy to identify the problem and cheap/easy to replace?
2007 SDR Full Akra Evo
2017 SDR 1290. Black
1997 RGV 250(sweet)
Re: '08 SDR
Postby No. 47 » Fri Feb 03, 2017 7:56 am
Aye, latest OE part seems to be better than superceded OE part, ie one that probably just failed, but best to go with Mosfet replacement - http://www.regulatorrectifier.com/catal ... -rectifier
Re: '08 SDR
Postby No. 47 » Sat Feb 04, 2017 1:20 pm
Same old stuff - broken reg/rec earth cable at battery eyelet but not sure if that was cause or happened removing reg/rec - so replaced reg/rec with old spare and Mosfet ordered.
Re: '08 SDR
Postby Sarasota_Steve » Sat Feb 04, 2017 3:05 pm
Good to know it was easy to diagnose and repair.
Did you order the reg/rec from the website you posted? That's a US site right?
Re: '08 SDR
Postby No. 47 » Sat Feb 04, 2017 3:17 pm
Aye, good service and fast delivery last time.
Similarly, have asked Joe for another one of these http://www.cycleterminal.com/horn-kits.html twin horn wiring kits in response to his note re not making anymore for a while - Eastern Beaver, another US, albeit ex-pat, electrical go to, has also stopped doing them - anyone know of another source?
CEREC1
Re: '08 SDR
Postby CEREC1 » Sat Feb 04, 2017 6:53 pm
No. 47 wrote:Aye, latest OE part seems to be better than superceded OE part, ie one that probably just failed, but best to go with Mosfet replacement - http://www.regulatorrectifier.com/catal ... -rectifier
I get the feeling I should buy one of these and either fit it or holding reserve. As I pretty well only use the bike for track days if the one on my bike fails I'll be stuffed at a circuit as regards a quick fix.
1997 RGV 250(sweet)
Re: '08 SDR
Postby No. 47 » Tue Feb 14, 2017 11:31 am
Just received - have to underline my recommendation - http://www.regulatorrectifier.com/catal ... -rectifier - great service and hassle-free Customs.
Re: '08 SDR
Postby No. 47 » Sun Feb 26, 2017 1:35 pm
Voltmeter dropped into red zone again but got home OK - swopped out temporary OE reg/rec for new Mosfet but voltmeter stayed in red zone - turned out to be faulty voltmeter so just goes to show once again, always check the bleeding obvious first.
Re: '08 SDR
Postby No. 47 » Sun Mar 05, 2017 9:07 pm
Question for those who with knowledge and experience of the dark art of electrics - I fitted a second set of earth and positive leads to the battery terminals on my 'old' SDR to avoid having to access the battery to add/replace components that should be directly connected to battery terminals eg twin horn wiring kit, trickle charger and Mosfet reg/rec - the Mosfet wiring isn't long enough to wire easily directly to the battery terminals so on my 'new' SDR I've connected the new Mosfet (and relocated the trickle charger wiring) to the main relay positive terminal and a separate new earth at one of the generator cover bolts - all seems OK but should these components really be connected physically to the battery terminals?
Re: '08 SDR
Postby No. 47 » Fri May 12, 2017 6:15 pm
Airbox fitted, SAS off, Jocke's map loaded, rearsets on bench ready, more mods ordered, so here we go again.........
Loco
Re: '08 SDR
Postby Loco » Fri May 12, 2017 8:04 pm
It never ends!, i keep looking at the healtech quickshifter, got some other stuff of theirs and it works great..
Now if I can just find some cash for it lol
Re: '08 SDR
Postby No. 47 » Wed Mar 07, 2018 3:29 pm
No. 47 wrote:Side of road in middle of nowhere with flat battery again..........
Ditto.............................it's that time of year again.
Return to General banter
