Will the 2016 Akra Evo full system fit on the 2017 SDR?
vet57air
Re: Will the 2016 Akra Evo full system fit on the 2017 SDR?
Postby vet57air » Tue Apr 04, 2017 11:58 pm
The can from my 2014 1290r is physically identical to the can on my 2016 GT. Interchangeable. I had taken out the DB killer out of the 2014 can and used it on my 2016 GT.
AlfaOne
Postby AlfaOne » Wed Apr 05, 2017 10:54 am
Thanks Vet57air, that's helpful. I think I'm just going to dive in & order a 16 slip on form SC Project & cross my fingers!
2017 1290SDR
99 ZX6R
Tancakar
Postby Tancakar » Thu Apr 06, 2017 12:23 pm
the 2017 STD catalytic converter is taken from GT so there for i don't think the old system full akro will fit the new bike. but this means there is may be a possibility that Full Akro system could be fitted to GT, sweet .
Tancakar
Postby Tancakar » Thu Apr 06, 2017 12:27 pm
if you remove the exhaust flap you will have TC error , you need a dummy part in side the Exhaust valve motor.
Postby Colonel_Klinck » Thu Apr 06, 2017 8:21 pm
Surely the Akra map turns off the error from removing the flapper in the exhaust?
Freude am Fahren
Postby Freude am Fahren » Thu Apr 06, 2017 10:54 pm
I would think so, as it does for the SAS.
AGRO!
Postby AGRO! » Fri Apr 07, 2017 4:43 am
This makes more sense (Freude am Reiten) :lol:
SuperDoopa
Postby SuperDoopa » Fri Apr 07, 2017 1:26 pm
AlfaOne wrote:Thanks Vet57air, that's helpful. I think I'm just going to dive in & order a 16 slip on form SC Project & cross my fingers!
I'm interested if this fits, as I might get one to ?
AlfaOne
Postby AlfaOne » Sun Apr 09, 2017 3:22 pm
Can is due to arrive on Tuesday 11th, unfortunately I don't get the bike till after Easter. Will keep you posted though & maybe even try a picture if it fits!
2017 1290SDR
99 ZX6R
AlfaOne
Postby AlfaOne » Sun Apr 23, 2017 10:27 am
SuperDoopa - it fits! Looks & sounds good
2017 1290SDR
99 ZX6R
Psalliss
Postby Psalliss » Fri Jun 30, 2017 5:27 pm
The akropovic system from earlier bikes does fit as just had a 2016 system fitted onto my 2017. Currently got the tv wanting light as not the akro map on at present but getting the map downloaded on Monday. Can't wait. I also presume the map disables the servo and the tc warning lights
Psalliss
Postby Psalliss » Sat Jul 08, 2017 9:32 am
Just an update. Had the full system from the 2016 which fits without issue and the servo just removed and the wiring wrapped in heat shrink and tucked away. No cap or dongle needed for it. The dash does come up with warning lights and all electrics seem to be disabled but runs fine. Once the akra map is on all lights go off. The akra. So fuelling is pretty good as put it back on the dyno afterwards.
Also power commander now have a map for the Akropovic's on a 2017 as they used my bike as development bike.
