Tips for changing a fork seal
bikelee
Postby bikelee » Fri Jun 09, 2017 2:05 pm
:( I have a leaking left front fork seal on my 2014 1290 SD. I've changed seals on many other bikes with Ohlins, Showa and Kayaba. Any quirks working on WP ? Thanks for any help or advice.
Re: Tips for changing a fork seal
Postby Aphex » Fri Jun 09, 2017 4:47 pm
I know my buddy at work needed special tools to work on my 990 forks.
Have you tried taking a bit of card stock and running it around the seal to see if something is just stuck in there?
bikelee
Postby bikelee » Fri Jun 09, 2017 8:24 pm
I'm gonna try that. I have a Seal Mate somewhere in the garage. I'll see if that alleviates the problem.
Postby Sarasota_Steve » Sat Jun 10, 2017 2:52 am
I heard 35mm negative film works great for that.
bikelee
Postby bikelee » Sun Jun 11, 2017 3:20 pm
:( I found my Seal Mate and have verified I DO have a leaky bad seal.
When i was pushing down and up on the forks I heard a distinct clicking noise. I thought it might be the steering bearings so I put the bike on a rear stand and lifted the bike from underneath with a jack and pulled and pushed the bottom of the fork and no play at the steering head. Any other ideas ??
Thanks !!
Postby REDTALE2000 » Mon Jun 12, 2017 1:53 am
Torque the top triple clamp nut.
They seem to work loose and the triple clamp will move just a bit on the stem and make that sound.
bikelee
Postby bikelee » Mon Jun 12, 2017 2:16 pm
REDTALE2000 wrote:Torque the top triple clamp nut.
:D Did the torque and it worked like a charm !! No more clicking. I wish the seal change would be that easy. Thanks for the great info.
Stu990
Postby Stu990 » Mon Jun 12, 2017 2:34 pm
:shock: what's that! :mrgreen:
coyo
Postby coyo » Wed Jun 14, 2017 1:33 am
If it's like the 990, I had to source out a very thin wrench in order to be able to get onto the nut with the spring compressed. Mine were too thick to fit. Other than that, pretty standard.
