Rottweiler intake problem
Kotari
Postby Kotari » Sat Nov 11, 2017 5:06 pm
Hello,
Does anyone who has rottweiler performance intake had any problems with it?
I noticed yesterday that my baseplate has cracked from the rear cylinder velocity stack to the back of the baseplate. I guess it's not easy to fix it because of the engine vibrations etc may crack it again..
-Kotari-
Now: KTM 250 EXC TPI Six Days 2019
Now: KTM 1290 Super Duke R 2017
Had: : KTM 1290 Super Duke R 2015 The beast.. Totalled..
Had: Suzuki GSX-R 1000 K8
Had: Kawasaki ER-6n 2007
michaeln
Re: Rottweiler intake problem
Postby michaeln » Sat Nov 11, 2017 6:06 pm
They do caution you to tighten the velocity stack bolts only to 55 inch pounds (which is only about 6Nm) and to use threadlocker. Did you do that while installing it?
Kotari
Postby Kotari » Sun Nov 12, 2017 7:12 pm
michaeln wrote:They do caution you to tighten the velocity stack bolts only to 55 inch pounds (which is only about 6Nm) and to use threadlocker. Did you do that while installing it?
Yes, i did the install as guided.
michaeln
Postby michaeln » Sun Nov 12, 2017 8:00 pm
Well, I guess next is to contact Rottweiler. You are going to need a new base anyway.
Do you have a picture of the breakage?
The Gin Reaper
Postby The Gin Reaper » Sun Nov 12, 2017 8:03 pm
they had a problem like this with the first gen 990 ones and sent out modded plates to customers - contact rotty would be my advice
Kotari
Postby Kotari » Sun Nov 12, 2017 8:26 pm
michaeln wrote:Well, I guess next is to contact Rottweiler. You are going to need a new base anyway.
I have a picture of it, but my photobucket doesn't work anymore. I have to get it right before i can add it here
Kotari
Postby Kotari » Sun Nov 12, 2017 9:56 pm
The Gin Reaper wrote:they had a problem like this with the first gen 990 ones and sent out modded plates to customers - contact rotty would be my advice
I did sent them email about it, but no response yet. Warranty time has been exceeded and it was fine over year and half before crack showed up. I will buy new baseplate from rotty after they responce to my email. Hopefully they give me some mercy and give me a little discount of it :roll:
Kotari
Postby Kotari » Wed Nov 22, 2017 3:09 pm
Okay, Rotty has sent me new base plate for warranty. I'm really pleased with the quality of customer service! :D This is just awesome! Once again +1 for the Rotty!
The Gin Reaper
Postby The Gin Reaper » Wed Nov 22, 2017 8:24 pm
Kotari wrote:Okay, Rotty has sent me new base plate for warranty. I'm really pleased with the quality of customer service! :D This is just awesome! Once again +1 for the Rotty!
Yup they are a stand up bunch......
