Blown head gasket
Blown head gasket
Postby Motogoon » Wed Dec 13, 2017 5:58 pm
So I've got a blown head gasket. Aaaaaaaargh
Last ride coolant blew out, temp was only on 4 bars. Bleed coolant system and refilled. Started with cap off and everything was fine until thermostat opened then coolant starts bubbling out, if I rev it it belches out all over the show.
This is the flippen 4th bike I've blown a head gasket on, I don't know what's with me and head gaskets!!
Anyway has anyone got any tricks for working out which cylinder it is without any specialized tools? The other bikes were inline four or single cylinder so no need to diagnose which one needed replacement.
There's no oil in the water and no water in the oil, looking at spark plugs doesn't seem to help as the coolant's not getting sucked in, just pressurized out.
Re: Blown head gasket
Postby Colonel_Klinck » Wed Dec 13, 2017 7:45 pm
990 or 1290? If its a 990 its pretty easy. Even easier if it the front cylinder as you can do it without moving the engine.
Postby No. 47 » Wed Dec 13, 2017 8:21 pm
Are you sure it's the head gasket?
Postby Motogoon » Wed Dec 13, 2017 8:37 pm
2005 990, it just the amount of strip down I have to do that sucks! I could a single cylinder in a couple of hours. That's why I'm hoping its the front so less tear down, just need to find out how to diagnose whether its front or back.
Pretty sure its the head gasket. I chased the other 3 bikes all over the place but in the end I've never found any other scenario that blows coolant out the radiator cap directly related to revs. If you have any other suggestions to try though I'm all ears, I'd love for it not to be be a head gasket! I've never even heard of an LC8 blowing a head gasket, just my freakin luck.
Postby Colonel_Klinck » Wed Dec 13, 2017 9:15 pm
It sounds like the head gasket. If it is blowing bubbles out of the coolant, even more so when you rev it I'd say it is the head gasket.
Do you have a compression tester? If so whip both plugs out and test it on turn over. It might work better with bike hot and thermostat open. Or whip thermostat out.
Postby Motogoon » Wed Dec 13, 2017 9:30 pm
No don't have a compression tester, was thinking maybe I could try somehow sealing a hose from the compressor on to the spark plug hole and see if bubbles come out the radiator. Good tip about the thermostat, I didn't even think about removing that before testing!
Postby Motogoon » Fri Dec 15, 2017 1:58 am
So I reckon I'm just gonna replace both head gaskets while the bike is stripped down, the rear has a slightly leaking base gasket anyway so I'll do base and head gaskets.
I'll have to order everything I need in one go because ktm New Zealand won't have anything in stock if I'm halfway through and forgotten something!
Let me know if I've missed anything obvious
2 x base gaskets
2 x head gaskets
8 x stronger studs (is there a little one that needs upgrading also?)
2 x copper washers for cam chain tensioners
2 x piston circlips
Do I need new head bolts/washers?
Postby Aphex » Fri Dec 15, 2017 3:15 am
Motogoon wrote:So I reckon I'm just gonna replace both head gaskets while the bike is stripped down, the rear has a slightly leaking base gasket anyway so I'll do base and head gaskets.
2 x base gaskets
2 x head gaskets
2 x piston circlips
Klinck did a bitchin write up with a full list of everything he used: http://www.superduke.net/forum/viewtopic.php?f=18&t=21371
Postby Colonel_Klinck » Fri Dec 15, 2017 9:18 am
Just glanced through that walk through. Damn I wouldn't fancy doing that again. Especially as the bloody thing dropped a valve 350 miles later and destroyed the rear cylinder, piston and head :cry: Still lesson learned, at 52k miles the valves were probably due to be changed and I was cheap and didn't change them.
Postby RichUK » Fri Dec 15, 2017 10:48 am
Just a thought but will the engine start/run with just 1 spark plug in?
If so pull one plug out and run the engine with the rad cap off, if you don't get bubbles it's likely is that one.
Postby Motogoon » Fri Dec 15, 2017 6:47 pm
Colonel_Klinck wrote:Just glanced through that walk through. Damn I wouldn't fancy doing that again. Especially as the bloody thing dropped a valve 350 miles later and destroyed the rear cylinder, piston and head :cry: Still lesson learned, at 52k miles the valves were probably due to be changed and I was cheap and didn't change them.
Gutted! Yeah I have read that a few times, very useful but at the same time it shows how daunting it is. I've rebuilt a few supermoto's and dirt bikes and they're sooo easy, tank off and you're ready to go.
Postby Motogoon » Fri Dec 15, 2017 6:49 pm
RichUK wrote:Just a thought but will the engine start/run with just 1 spark plug in?
That's an idea, anyone know if it will run with a plug out, will gas spray out? I'd have to have it hot enough for the thermostat to be open also. Starting to sound a bit dodgy!
Postby No. 47 » Fri Dec 15, 2017 7:32 pm
Run engine up to temperature, disconnect each coil pack and run engine in turn.
Postby Colonel_Klinck » Fri Dec 15, 2017 9:11 pm
It won't run on one cylinder. Without a compression tester you are going to struggle to find out with cylinder it is. Even with one it might not be down by a large amount. You will probably need to remove the thermostat as well as I'm guessing it opens somewhere around 80c. It won't take long for the coolant temp to drop back down and the thermostat to close. As you'll be turning the engine over coolant will continue to circulate through the rad cooling it.
If I was you I'd just bite the bullet, whip the engine out and change both. You have to change the base gaskets as well as the cylinder is held in place by the same bolts that hold the head on. It isn't that difficult. That walkthrough was way more complicated as I was changing the timing chains as well. Just make sure you have the engine in TDC for each cylinder when you remove the cams and put them back. Oh and either buy or make yourself a locking bolt. I can't remember what the bolt size is now, just needs grinding to a point on the end you insert into the engine.
Postby No. 47 » Fri Dec 15, 2017 9:26 pm
Both of mine have run, reluctantly, on one.
Postby Motogoon » Fri Dec 15, 2017 9:32 pm
Colonel_Klinck wrote:It won't run on one cylinder. Without a compression tester you are going to struggle to find out with cylinder it is. Even with one it might not be down by a large amount. You will probably need to remove the thermostat as well as I'm guessing it opens somewhere around 80c. It won't take long for the coolant temp to drop back down and the thermostat to close. As you'll be turning the engine over coolant will continue to circulate through the rad cooling it.
Yep you're right, I will just do both instead of trying trying to find ways to weasel out of a full strip down!
Ah yes the lock bolt, I forgot about that. On single cylinder bikes I just used to take the power bar that was on the flywheel nut and zip-tie it to the footpeg so the engine couldn't move.
Suppose I need exhaust gaskets too
Postby Colonel_Klinck » Fri Dec 15, 2017 10:39 pm
You will be unlucky if they disintegrate. I would buy the rubber cam cover gaskets though. You'll be gutted if you put it back together only to find one leaks. Check the valve clearances while you're at it. Harley Davidson shims fit and come in far more sizes. Download this shim excel doc. Works it all out for you https://www.dropbox.com/s/kqorujpuuk9s7 ... s.xls?dl=0
DaveNZ
Postby DaveNZ » Sat Dec 16, 2017 3:51 am
2 x base gaskets
2 x head gaskets
2 x piston circlips
the forgotten highway is my favourite loop, urenui-artiti-tahora-whangamomona-strathmore-tarata to home in urenui, 200kms of windy back roads, ktm country.
Postby Motogoon » Mon Feb 05, 2018 12:55 am
Have all the parts and finally about to start this job but was wondering if there's a way to remove the oil tank with the oil still in there or does it have to be drained first?
SD05
Postby SD05 » Mon Feb 05, 2018 1:47 pm
Drain the oil tank.
Postby Motogoon » Tue Feb 20, 2018 4:38 am
So got the beast back together, only a 50km test ride (in stinking hot weather so a good test I think) and all seems good so far.
Few things I found in the process.
For the most part its pretty easy to work on but a couple of things were a real bitch, especially the piston clips (worst I've ever dealt with) but I must have worked out a technique in the hour I messed around with the first one because on the second piston I popped it straight in. (stabbed a screwdriver through my nail on the first one too)
I had to bleed the coolant twice, first time I only had the bike raised about 40cm so that may have been why, second time over 50cm worked.
Only one valve was out of spec at .32 (exhaust)
I put a very thin bead of three bond sealant on the valve cover gaskets as the front looked like it had leaked slightly and I didn't have new ones available to replace them.
Couldn't get the proper KTM adapter so I used a shorty 13mm ring spanner with a 1/2" drive torque wrench in the open end for the outer head nut. Tried first at 90 degrees with the same torque value but wasn't 100% convinced so used an online calculator with it straight on and clicked at the same point.
Anyway this is the order I removed parts & it seemed fairly efficient.
-Seat, shrouds, tank, belly pan.
-Water reservoir
-Throttle cables at throttle body
-Throttle bodies/airbox/breather/sensor
-Radiator (after draining coolant system)
-Oil tank (left oil in)
-Exhaust headers (left akra's in place)
-Battery
-Loosened battery box and left in place under bike
-Front engine mounts
-Coolant hoses (just 2 hose clips by heads)
-Starter motor (now a real good clean around the base of the cylinders so no crap falls in when lifting)
-Removed 2 screws holding hard oil line running past right side of front cylinder so it would move out of the way while lifting the head
-Spark plugs then fitted the engine lock bolt (home made from threaded rod) at top dead centre for front cylinder.
-Checked valve clearances then lifted the barrel/head and replaced head/base gaskets and studs and reassembled all as per workshop manual
With that buttoned up moved to the rear which needed tilting forward in the frame
-Gear linkage off the engine
-Rear wheel
-Swingarm pivot bolt (supported engine first with tie down around front barrel, frame supported on stands under rear sets)
-Front wheel/guard
-Lowered engine at front till room for the head to come out (at this point maybe 500mls of engine oil came out of the crank locking bolt hole/ I should've rotated it to tdc rear and put the bolt in before tilting and I probably would have lost bugger all.
-Replaced gaskets etc as per manual
Wrote this list as I went then just ticked them all off in reverse for reassembly, also rotated engine a few times and rechecked valve clearances before throttle bodies and spark plugs were re-installed.
Postby Sarasota_Steve » Tue Feb 20, 2018 12:53 pm
Good on you man! Oddly satisfying and frustrating working on our beloved beasts. I think the sense of satisfaction once you are done fixing it has to tickle or primal instincts and make us feel like manly man. And its typically a learning experience and saves us money at the same time.
And in my case I'm thinking "I'd like to get something new, shiny, different. But I've done so much work on this bike already, bought the special tools, I know exactly how it's been maintained and repaired that might as well keep it"
Mr_Trecolareco
Postby Mr_Trecolareco » Tue Feb 20, 2018 1:16 pm
Nice writeup 8)
Hope everythings stay well for a long time 8)
Postby Aphex » Tue Feb 20, 2018 3:41 pm
Great write up, I'll be referring to this and Klincks when I do mine.
What method did you figure out for the piston clips?
Postby Motogoon » Tue Feb 20, 2018 6:43 pm
Sarasota_Steve wrote:Good on you man! Oddly satisfying and frustrating working on our beloved beasts. I think the sense of satisfaction once you are done fixing it has to tickle or primal instincts and make us feel like manly man. And its typically a learning experience and saves us money at the same time.
Thanks, Yeah I enjoy the parts that go smoothly and the satisfaction when finished. I hate to think what the labour cost would be to pay a dealer to do it!
Users browsing this forum: Baidu [Spider], Google [Bot] and 1 guest
