990 not starting
ernie
990 not starting
Postby ernie » Tue Oct 24, 2017 1:42 pm
Hi all, I have an 07 990R 18k miles with full ti Akrapovic, motohooligan intake, SAS rmeoved etc. no issues at all for 6k miles since bought, mostly used on track and Sunday rides. I have an electrical issue with it now I cant figure out, hoping you can help.
Current issue is lights and dash turn on, fuel pump does not prime and starter does not turn.
Some back story, I was on a trackday and bike slowly stalled with FI light on constant and would not rev properly. Back at the pits the bike started fine and idled fine, giving it throttle and keeping it at steady rpm it would bounce up and down the revs. Called it a day and went home, next day cleaned connections near the battery and the BGC with servisol isopropyl alcohol, let it dry and sprayed servisol silicone grease. Bike started fine, did 15 minute idle, went for a ride and after 150 miles bike did the same as on track, slowly lost power, would not rev with a constant FI light, then would not start at all. Back home again, checked fuses with millimeter all fine, cleaned BGC again, unplugged TPS and put back in, and it started then reved it it dies with solid FI light and would not start again.
I also tried to connect to TuneECU with 3 different computers with different operating systems and could not connect, either I cant setup TuneECU properly or it cant read the 990 ECU, could the BGC be causing all this?
What are your guys thoughts on this?
Thanks
Ernie
Re: 990 not starting
Postby No. 47 » Tue Oct 24, 2017 4:46 pm
Where are you based?
ernie
Postby ernie » Tue Oct 24, 2017 5:12 pm
No. 47 wrote:Where are you based?
East London
Postby No. 47 » Tue Oct 24, 2017 6:45 pm
Think first step is getting you hooked up to TuneECU (though gut feel is that problem might be battery and/or reg/rec and associated wiring) - happy to come to you with TuneECU loaded laptop or, preferably if you think you’ll make it, come here as I have spare TPS, etc.
Postby No. 47 » Tue Oct 24, 2017 7:07 pm
PS - depending on where you are precisely, I’m 30-60 mins away in Kent.
ernie
Postby ernie » Wed Oct 25, 2017 6:53 am
No. 47 wrote:PS - depending on where you are precisely, I’m 30-60 mins away in Kent.
That would be great if you can, very helpful. I will PM you.
ernie
Postby ernie » Sat Oct 28, 2017 4:25 pm
So after charging battery and cleaning the BGC again the bike connected to TuneECU, there was no errors. I started the bike, it idled for couple of minutes, then it stop, power still on and I got 3 errors come on TuneECU and it told me ECU is no longer connected and i couldn't start the bike again. the Errors were:
p0122 - throttle position sensor low voltage (short to ground or open circuit)
p0201 - injector 1 circuit malfunction
p0202 - injector 2 circuit malfunction
I left the bike for couple of hours went back to it and it started, idled fine, gave it throttle no problem. switched the bike off and the back on again and it wouldn't start again, and no TuneECU connection. Its as if the bike cant connect to the ECU to start.
Thoughts on this?
Postby No. 47 » Sat Oct 28, 2017 5:26 pm
As per PMs, gut feel for first check is whether battery is holding charge even though you may not be getting red battery warning light.
ernie
Postby ernie » Sun Oct 29, 2017 3:39 pm
Tested the battery today, was fully charged last week. Readings are:
Ignition off: 12.5
Ignition on: 12.3
Engine running: 13.8
Here are some pictures of the bike connected to TuneECU
Ignition on:
Engine Running:
Postby No. 47 » Sun Oct 29, 2017 8:00 pm
So, no error codes either - what happens to battery voltage when engine is kept running and at point when it stalls?
ernie
Postby ernie » Sun Oct 29, 2017 9:55 pm
No. 47 wrote:So, no error codes either - what happens to battery voltage when engine is kept running and at point when it stalls?
It hasn't stalled today or fail to start at all today, will try again tomorrow to see if stalls
Miff_UK
Postby Miff_UK » Sun Oct 29, 2017 11:57 pm
Watching..
ernie
Postby ernie » Mon Oct 30, 2017 6:56 pm
Typical... starts and runs fine every time now, have had the bike in the house for a few nights now, maybe something dried?
Postby No. 47 » Mon Oct 30, 2017 7:50 pm
Cold kills battery capacity to hold charge.............................
ernie
Postby ernie » Wed Nov 01, 2017 8:14 am
last night still starting fine, im going to have in the house for couple of months to do valve checks, water pump rebuild etc.
is it worth buying another battery then? same as the stock or are there lighter more reliable options?
Postby No. 47 » Wed Nov 01, 2017 10:28 am
Lot's of threads on here re OE v alternatives including lithium batteries - my simple view is that OE Yuasa battery is best option but buy online or, better still, from a Honda dealer, and not from KTM, as much cheaper.
Postby No. 47 » Wed Nov 01, 2017 10:40 am
ernie
Postby ernie » Wed Nov 01, 2017 1:43 pm
Thanks, will get a new battery after i do all the serving. Hopefully this will fix the issue
Appreciate the help
Spike_africa
Postby Spike_africa » Wed Nov 01, 2017 2:39 pm
My Street Triple did similar things and a new battery fixed it.
2007 SD 990
2009 Triumph Street Triple
Postby No. 47 » Fri Nov 03, 2017 1:17 pm
No. 47 wrote:PS - just bought one here https://www.ebay.co.uk/p/Genuine-Yuasa- ... 2268988042
Just arrived - Yuasa branded battery in a Honda branded box, £64.50 delivered, from Padgett Honda.
ernie
Postby ernie » Fri Apr 13, 2018 9:26 am
Update.
Have replaced the battery, fuel pump/filters, spark plugs and coils, tested rectifier and cleaned/greased BGC multiple times, TPS voltage is correct, done 15 min idle reset.
bike has been starting fine only ones the fuel pump did not prime and disconnect and reconnect BGC fixed issue. most common issue now is while riding the bike loses power for a second with FI light, doesn't matter what speed, gear or RPM. for example doing 70mph around 6k rpm steady throttle bike will lose engine power for a second drop down to 5k rpm and kick back into power really quick, sometime happens ones or it would keep repeating every so often, this lose of engine power and kick back keeps repeating until engine struggles to keep power and eventually engine dies, wheels do no lock up, dash does not turn off, only FI light shown. switching ignition or kill switch will start the bike after and it would be fine for a few more miles until it would happen again. sometimes doesn't happen for 50 miles. TuneECU does not report an errors after.
any thoughts? Im tempted to buy another injection unit and wiring loom of ebay to eliminate it being injection/TPS/BGC unless all of this is caused by ECU?
Postby No. 47 » Fri Apr 13, 2018 10:19 am
Not clear - have you replaced the fuel pump itself or just the filters?
ernie
Postby ernie » Fri Apr 13, 2018 12:36 pm
No. 47 wrote:Not clear - have you replaced the fuel pump itself or just the filters?
sorry, yes replaced both fuel pump and filters.
Postby No. 47 » Fri Apr 13, 2018 3:42 pm
Take it to Paul R. on the Old Kent Road.
ernie
Postby ernie » Fri Apr 13, 2018 6:37 pm
No. 47 wrote:Take it to Paul R. on the Old Kent Road.
Don’t know who that is can you confirm address please
