O2 sensor exhaust block off plugs
Postby bic_bicknell » Sat Aug 21, 2010 11:52 am
I seem to remember a thread where someone put a link to a site where you can get the screw in thingymibobs to blank off the threaded holes left in the header pipes if you remove the O2 sensors.
I think they were generic car ones maybe.
Got a new exhaust system coming and may as well remove the sensors as I've disconnected the whole electrical system anyway.
Anyone know what bits I need or where to get them from?
Ta.
whufc0
Postby whufc0 » Sat Aug 21, 2010 12:26 pm
I ended up getting theses, not fitted them yet though.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... _500wt_694
Postby bic_bicknell » Sat Aug 21, 2010 5:14 pm
I think this is what I meant.
cat
Postby cat » Sat Aug 21, 2010 7:55 pm
You have to grind out the weird blockages in the bungs that stop you screwing in the plugs. I didn't want to take off the exhausts to do that so I used a stack of washers.
Razy
Postby Razy » Sat Aug 21, 2010 8:20 pm
whufc0 wrote:I ended up getting theses, not fitted them yet though.
SHIT THE BED!!! there expencive!!
just go to rapid exhaust and there only £1.80 each.
whufc0
Postby whufc0 » Sat Aug 21, 2010 8:22 pm
For the time it would take me to goto the nearest rapidfit and petrol money etc, im better off getting them from ebay
Postby bic_bicknell » Sun Aug 22, 2010 7:29 am
Thanks whufc.
That is exactly the link I was looking for. (If those are the right thread and diameter. I guess you did the research? I'll trust your judgement :wink:)
whufc0
Postby whufc0 » Sun Aug 22, 2010 9:07 am
Your more then welcome to try mine, if u want them quickly, i not gonna use mine till bike is off road in winter.
Postby ktmguy » Sun Aug 22, 2010 9:37 am
There is a link on here how to open up the hole a bit so you can use of the shelf cheap plugs. Use a hole saw and a spanner. 5 min job. no need to take the exhaust off.
jehadjoe
Thunder pumpkin rider
Postby jehadjoe » Tue Aug 24, 2010 8:16 pm
Yea a dremel will also work but the back one is at a weird angle, I would like some of those plugs in aluminium.
