FI Black 3D
FAQ  •  Search  •  Photo Gallery •  Memberlist  •  Usergroups   •  Register  •  Profile  •  Log in to check your private messages  •  Log in
 Paint-Job View next topic
View previous topic
Post new topicReply to topic
Author Message
Baby_Dave
PostPosted: Wed Jul 23, 2008 9:10 pm Reply with quoteBack to top
Do any of you guys have any experiences or opinions on powder coating verses a proper spray job?
The reason I ask is that I'm probably going for a black swingarm and presumed from other peoples comments on other forums that powder coating is the only way forward. Having spoken with the PC company they suggested that the only advantage with PCing is the speed of the work. However they have a build up of work and would not able to turn it around within the week anyway.
A real good guy who does any spraying for my car said he could take the bike in and have it back the next day.
What are you're guys thoughts on this and the results?
Cheers,
BD
View user's profileSend private message
SDSmurf
PostPosted: Wed Jul 23, 2008 9:17 pm Reply with quoteBack to top
No expert here, but I was also tempted to powdercoat the swingarm - I was advised by most on this forum to rather anodise it black, which is how the 08 and SD-Rs' swingarms are done.
Reasons? Clearance of chain adjuster blocks and such, with powdercoating.
Again, from what I've heard normal paint will chip quickly and easily...
Stand to be corrected...
_________________
The SD needs corners like I need red meat.
Baby_Dave
PostPosted: Wed Jul 23, 2008 9:30 pm Reply with quoteBack to top
That's the opinion I had as well.
Anyone else had any exeriences?
BD
jehadjoe
Thunder pumpkin rider
PostPosted: Wed Jul 23, 2008 9:33 pm Reply with quoteBack to top
hey gents, I have just powder coated my own exhaust header on my SD, (from a spray can) i have pics if yer interested?
it is very tricky, extremely delicate when applied prior to heat treating. it requires a heating cycle so you really need an out door oven.
mine worked a treat, mainly cos you can heat treat the pipe from the heat of the engine, I would like to anodize my swingarm also, powder coating is
thick, I like the staining of the metal that anodizing does, Paint does not weather well for MC parts from what I have seen, but by far the easiest.
also powder coating is VERY durable when professionally applied, last for eons.
9nine0
PostPosted: Thu Jul 24, 2008 12:49 pm Reply with quoteBack to top
Joe, post some pictures.
_________________
2007 990 SuperDuke
2004 950 Adventure "GO"
2003 450SX
superdude
PostPosted: Thu Jul 24, 2008 1:21 pm Reply with quoteBack to top
Hey Joe! I have trouble reading your posts. For some reason my eyes keeps going left Laughing .
_________________
DO WORK!
9nine0
PostPosted: Thu Jul 24, 2008 3:08 pm Reply with quoteBack to top
Same here until he changed to the horse..
_________________
2007 990 SuperDuke
2003 450SX
jehadjoe
PostPosted: Thu Jul 24, 2008 4:19 pm Reply with quoteBack to top
superdude, when i had first came here, people could not understand me.... this is why I lay my sentences out with space between, joe is a scatter brain.
the girl was too cheap looking for my tastes, i can stick her back up but finding these moving tittie avatars is hard. Bodge has the killer one and pugwarsh too.
Mr_Trecolareco
PostPosted: Thu Jul 24, 2008 4:56 pm Reply with quoteBack to top
OT:
joe, just for you Smile
Good luck searching:
http://www.sherdog.net/forums/f7/gif-thread-2-0-a-668876/
Edit:
e.g
_________________
Um abraco e mto boas curvas!! Smile
Khaos
PostPosted: Thu Jul 24, 2008 5:35 pm Reply with quoteBack to top
Anodizing can be tricky and you will have to check with the vendor who is performing this operation as to the final results. One of the problems is that anodizing will increase the size of any holes or slots that are on the part, opening up tolerences which can create issues upon reassembly.
jehadjoe
PostPosted: Thu Jul 24, 2008 5:56 pm Reply with quoteBack to top
Khaos Thanks for that,,that is enough for me not to jack wit it.
Mr_Trecolareco, this is the best one so far, joe is married to an Asian girl, they are the cream of the crop in my eyes, a twisted one am I.
daws
PostPosted: Fri Jul 25, 2008 3:53 am Reply with quoteBack to top
I get a LOT of parts powdercoated and anodised for work.
Powdercoat is amazing durable but it causes a build up on parts so is not good for closely toleranced areas. It's ideal for frames and wheels but you have to ensure that any bolt holes or bearing seats are masked or plugged.
Cosmetic anodising (as opposed to Hard anodising) is typically 12-20 microns thick, some of this is below the surface of the material. It will not generally cause any issues with clearance UNLESS it's a very tightly toleranced part like a sweated in bearing. All of the aluminium parts on your bike are already anodised but it's a clear anodising - the Anodiser will strip the factory coating and re-anodise with a colour dye to stain the oxide layer. Cosmetic anodising is not as durable as Powdercoating.
To cut a long story short (too late!) I'd anodise the swinger. I'm just about to send my set of spare levers to get black anodised.
Khaos
PostPosted: Fri Jul 25, 2008 12:49 pm Reply with quoteBack to top
True, Daws.
The anodizing type depends on the vendor performing the work, which is why I stated to check with them prior to going this route. It can be done you just have to do a little research first. I am not sure of the results when you anodize a part that already under gone this process.
Display posts from previous:
 Jump to:
View next topic
View previous topic
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001/3 phpBB Group :: FI Theme :: All times are GMT + 1 Hour
